Need help, could not find wireless option.
Hello
I have a MikroTik router model: “RB2011USA-2HnD-IN” which has built in wireless but i could not find the wireless setting option under the Webfig/Winbox interfaces option. Please kindly help.
Its RB2011UiAS-2HnD-IN model
first do system reset - than if wifi don’t show
go in to system->package check if wireless.npk is missing or disabled
What Lakis suggested would work, but easier would be to run Netinstall with the latest RouterOS version v6.10 (you have v6.1). It will fix any problems and upgrade software at the same time.
http://wiki.mikrotik.com/wiki/Manual:Netinstall
Thanks a lot
