Hi All,
I recently found that my network is having a rather weird issue, that I cannot access [www.myq.com](http://www.myq.com), or to be precise 204.183.221.47 or 50.224.141.47. I get connection timeout from both.
I’ve already isolated ISP issue, that when I connect to Internet directly using my laptop’s ethernet port it works perfectly fine.
When I do a traceroute, the first hop (my router, RB4011 with newest ROS 7.3.1) will timeout.
I’ve tried to disable the firewalls, it did not help. Nor did I find and DROP rules rejected this packet (I have logs enabled).
As for context, I think this issue first occurred about end of 2021 or Jan 2022. It is probably related to me upgrading this router to ROS version 7 but I cannot verify.
Could you help me diagnose this issue?
