Need help editing script for voucher use
Hi All,
I'm super new to this, therefore, I've had someone help me create a Hotspot profile script for 3-hour & single day vouchers in winbox, but have run into some issues of the script not executing as needed.
FYI - in Mexico hence the wording in script below
  1. Would like it to have the current user comment also show up in the Active comments
  2. Be able to see the session time left in Active tab
  3. Fix that the vouchers are not deactivating and deleting when time is up
  4. Is there a way to keep a record of information from expired vouchers which contains the User name, MAC, date & time activated, and voucher type (day or 3-hour) or the profile name used
    :local tdias 0
    :local thoras 3
    :local atime [ /system clock get time ]
    :local adate [ /system clock get date ]
    :local temp1 [:pick $adate 0 3]
    :local temp2 [:pick $adate 4 6]
    :local temp3 [:pick $atime 0 5]
    :local temp4 ($adate." - ".$temp3." Horas: ".$thoras);
:if ( [ /ip hotspot user get $user comment ] = "" ) do={ [ /ip hotspot user set $user comment=$temp4 ] }
Agrego un registro en el LOG del usuario (Create registry in LOG)
/log info "Usuario= $user $adate $atime Dias: $tdias ";
:local mesarray ("Jan","Feb","Mar","Apr","May","Jun","Jul","Aug","Sep","Oct","Nov","Dec")
:local diaarray ("31","28","31","30","31","30","31","31","30","31","30","31")
:local day [:pick $adate 4 6]
:local monthtxt [:pick $adate 0 3]
:local year [:pick $adate 7 11]
:local months ([:find $mesarray $monthtxt])
:local dia ([:pick $diaarray $months])
:local fhora [:pick $atime 0 2]
:local fminutos [:pick $atime 3 5]
:local fsegundos [:pick $atime 6 9]
:local mayorhora (($fhora+$thoras)-24)
:if (($fhora+$thoras)>23) do={
:set atime ("0".$mayorhora.":".$fminutos.":".fsegundos);
:set $tdias ($tdias+1);
} else={
:set atime (($fhora+$thoras).":".$fminutos.":".fsegundos) ;
:if (($day+$tdias)>$dia) do={
:if ($months=11) do={
:set months 0;
:set year ($year+1);
:set day (($day+$tdias)-$dia);
:local mes ([:pick $mesarray $months]);
:set adate ($mes."/".$day."/".$year);
} else={
:set months ($months+1);
} else={
:set day ($day+$tdias);
[/system scheduler add name=$user on-event="/ip hotspot user remove "$user" \r
\n/system scheduler remove [find name="$user"] \r
\n/ip hotspot active remove [find user="$user"] \r
\n/\r
" start-date=$adate start-time=$atime]
