Need help for making a VPN on a Mikrotik router
i need help to setup a VPN connection to a Mikrotik router, if anyone can help please let me know.
I tried many tutorials and it never works.
Im able to access the device currently only if im on the same network, as soon as i change my network connection i lose the abiility to access it with Winbox.
If someone could team viewer with me for help on how to do it or help anyway i would apreciate.
Thanks.
Hmm… What VPN protocol you like use? Mikrotik support many different VPN protocol.
I recommended you post your config here, you can export your config with /export command on terminal.
Have you changed your firewall?
You need to accept several ports…
