Router OS version: 4.17
First of all I am a newbie. I have tried to edit mac address of my arp table using a php script. The code of the php script is as follows:
<?php
require('routeros_api.class.php');
$API = new routeros_api();
$API->debug = true;
if ($API->connect('223.27.115.4', 'admin', '')) {
$API->write('/ip/arp/edit', false);
$API->write("=.id=*2",false);
$API->write('=value-name=mac-address',true);
$API->write('=mac-address=13.13.13.13',true);
$READ = $API->read(false);
$ARRAY = $API->parse_response($READ);
print_r($ARRAY);
$API->disconnect();
This return the following message.
Connection attempt #1 to 223.27.115.4:8728… <<< [6] /login >>> [5/5 bytes read. >>> [5, 39] !done >>> [37/37 bytes read. >>> [37, 1] =ret=dfb945995c2ab92b6c4409f132609554 <<< [6] /login <<< [11] =name=admin <<< [44] =response=0061bff1e3a42a07d1323460ddd81f9534 >>> [5/5 bytes read. >>> [5, 1] !done Connected… <<< [12] /ip/arp/edit <<< [7] =.id=*2 <<< [23] =value-name=mac-address <<< [24] =mac-address=13.13.13.13 >>> [5/5 bytes read. >>> [5, 64] !trap >>> [9/9 bytes read. >>> [9, 54] =message= >>> [5/5 bytes read. >>> [5, 47] !done >>> [5/5 bytes read. >>> [5, 40] !trap >>> [31/31 bytes read. >>> [31, 8] =message=no such command prefix >>> [5/5 bytes read. >>> [5, 1] !done Array ( [!trap] => Array ( [0] => Array ( [message] => ) [1] => Array ( [message] => no such command prefix ) ) ) Disconnected…
Please help. I need it urgent. Please fix my php script.
Thank you.
