Hi, i need help for port forwarding configuration.
I have a router (RB750Gr3) with these connections:
Ethernet 1: INTERNET from an external antenna LHG LTE18 with sim card (public ip).
Ethernet 2: Dekstop Pc (static ip)
Ethernet 3: Alarm Hub
LHG LTE = eth1 192.168.188.1/24
Router = bridge lan—>192.168.13.1/24
i want to open ports for Ethernet 2 (desktop pc) for gaming.
and i tried these settings for lte
and these are the firewall rules for lte
thanks
Just to make sure I am clear on the concept, you have two routers involved. First is your microwave radio LHG and then that is feeding the RB750. That means your NAT needs to be NATTed in both routers. Instead of screen captures (which only give partial information, please export your configuration for BOTH routers.
To export and paste your configuration (and I’m assuming you are using WebFig or Winbox), open a terminal window,
and type (without the quotes) “/export hide-sensitive file=any-filename-you-wish”. Then open the files section
and right click on the filename you created and select download in order to download the file to your computer.
It will be a text file with whatever name you saved to with an extension of .rsc. Open that file in your favorite
text editor and redact any sensitive information if desired / needed. Then in your message here, click the code
display icon in the toolbar above the text entry (the code display icon is the 7th one from the left and looks
like a square with a blob in the middle). Then paste the text from the file in between the two code words in brackets.
If your mobile provider give you a public IP and is not using CGNAT, then instead of setting up your system to have a private IP between the LHG and the HEX, you can consider to use the passthrough so that the LHG is used only as modem and the public IP is assigned directly to the WAN interface of the HEX.
In this way you avoid double NAT.
Otherwise you ahve to make sure that in the FW of the LHG you are allowing the traffic to be forwarded back to the HEX.
As reference here the config in passthrough of my SXT. I removed my data buy yu need to replace apn= with the fqdn of your APN.
In my case I’m using a vlan to do passthrough to keep eth1 for management but this is not mandatory and you can use RoMON to connect to LHG.
I prefer VLAN because in this way I can manage to have SXT using my HEX-S to have internet that simplify the upgradate of ROS instead of having to copy the file manually (I know I’m lazy
/interface lte apn
set [ find default=yes ] apn=apn.com default-route-distance=1 name=\
myapn passthrough-interface=vlan254-lte-passthrough passthrough-mac=\
auto use-network-apn=no
Yeah the real concern is if the OP ever actually gets a public IP. If so, as stated forwarding port from LTE to hex WANIP ( lanip of hex on LTE subnet) and then forwarding from hex to device will work just fine, but concur, the sweeter solution is using the hex to terminate the public IP.
First of all, thanks for your help.
Because i want to manage the Lhg, if its possible to help me, because im a beginner, how to set up firewall in LHG to allow traffic to the HEX.
Thanks!
And withouth sarcarsm, what is the expected value of managing the LHG as stand alone?
I see your current config is the out of the box, if we exclude that you changed the ip of the default subnet from 192.168.88.0/24 to 192.168.188.0/24 and you added the dstnat rules.
If you really want to keep it as your gateway, then you could consider to remove the masquerade on the HEX and just keep the NATting to the IP of your provider only on the LHG.
Or do you have specific reason to leave the double NAT in place?
Thanks for your answer,
I made a request to my provider, to activate this apn profile for me.
Because i m sharing the antenna with my friend in another apartment and the antenna is to the top of the building, sometimes because the provider’s antenna is in a central point, during peak hours, i m changing bands so we can achieve better speed results, so it would be better for me to have access with the easy way.
I understand, but I think I confused you, my bad.
When I said that with pass through you get a “dumb device” I meant that don’t have to worry about firewall and routing as these are delegated to your main router, but the device remain accessible and you can still manage and modify manually whatever parameter of the LTE interface.
Just make sure to enable romon or setup a vlan for management before enabling the passthrough.
First I tried to enable romon and then setup a vlan for management. I enabled passthrough but i have problem with the ports. I cant open them When i hit the ports on CanYouSeeMe, although it says close i get packets in winbox, but only in tcp ports, not in udp.
And in cmd, i take this result only in one port,
C:\WINDOWS\system32>netstat -an | find “3074”
TCP 192.168.13.243:50404 xxx.xx.xxx.xx:3074 ESTABLISHED
UDP 0.0.0.0:3074 :
Its the port for call of duty, and it opens when i run the game.
Settings for LTE
/interface vlan
add interface=ether1 name=management vlan-id=2
add interface=ether1 name=network vlan-id=3
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface lte apn
add apn=internet name=provider name-Passthrough passthrough-interface=ether1 \
passthrough-mac=auto
/interface lte
set [ find default-name=lte1 ] allow-roaming=no apn-profiles=passthrough-vpn \
band=1,3,7 network-mode=lte
/ip hotspot profile
add name=default-dhcp ranges=192.168.188.10-192.168.188.254
add address-pool=default-dhcp disabled=yes interface=ether1 lease-time=10m \
name=defconf
/port
set 0 name=serial0
add comment=defconf interface=ether1 list=LAN
add comment=defconf interface=lte1 list=WAN
add interface=management list=LAN
add address=192.168.188.1/24 comment=defconf disabled=yes interface=ether1 \
network=192.168.188.0
/ip dhcp-client
add address=192.168.188.0/24 comment=defconf dns-server=192.168.188.1 \
gateway=192.168.188.1
set allow-remote-requests=yes servers=8.8.8.8
/system clock
set time-zone-name=Europe/Athens
/system identity
set name=MikroTik-LTE
/system note
set show-at-login=no
/tool mac-server
/tool mac-server mac-winbox
/tool romon
set enabled=yes
