Need help for port forwarding
Hallo all.
I need some help because my port forwarding doesn’t work correctly.
I have rb750gr3 and 2 virtual servers with turned off firewall based on RHEL 9.
Before port forwarding i try nmap external IP from local and wan. Ports 25565 and 80 are closed.
After port forward i also try nmap external IP from local and wan.
Ports 25565 and 80 are filtered.
After that i add nat rule for local network and porst 25565 and 80 are open, but nmap from wan says that ports are filtered.
I asked the provider if there are restrictions on port blocking. They said what no rules are bloking my ports.
That’s my firewall export:
[admin@MikroTik] > ip/firewall/export
# oct/20/2023 16:31:40 by RouterOS 7.9.2
# software id = SZTP-T6JT
# model = RB750Gr3
# serial number = <serial>
/ip firewall address-list
add address=x/30 list=WAN
add address=192.168.10.0/24 list=LAN
add action=accept chain=input dst-port=500,1701,4500 in-interface=ether1 \
    protocol=udp
add action=accept chain=forward connection-nat-state=dstnat dst-address-list=\
    WAN dst-port=25565 protocol=tcp
add action=accept chain=forward comment="allow port forwarding" \
    connection-nat-state=dstnat connection-state=new in-interface-list=WAN
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
add action=masquerade chain=srcnat dst-address=192.168.10.6 dst-port=25565 \
    protocol=tcp src-address-list=LAN
add action=masquerade chain=srcnat dst-address=192.168.10.7 dst-port=80 \
add action=dst-nat chain=dstnat dst-address-list=WAN dst-port=80 protocol=tcp \
    to-addresses=192.168.10.7
add action=dst-nat chain=dstnat dst-address-list=WAN dst-port=25565 protocol=\
    tcp to-addresses=192.168.10.6 to-ports=25565
    udp to-addresses=192.168.10.6 to-ports=25565
    ipsec-policy=out,none out-interface-list=WAN to-addresses=x
/ip firewall service-port
set ftp disabled=yes
set sip disabled=yes
Please help me because i don’t no what to do next.
I’m too need help in very basic port forward. I’m reset everything already still same cannot see the open port.
I’m testing using 8888 and all time failed. Followed all youtube guide, website guide all teach the same thing, there is nothing can work. I attached the configuration for you guy.
FOR NAT:
Flags: X - disabled, I - invalid; D - dynamic
0 ;;; defconf: masquerade
chain=srcnat action=masquerade out-interface=UniFi log=no log-prefix=“” ipsec-policy=out,none
1 chain=dstnat action=dst-nat to-addresses=192.168.1.100 protocol=tcp in-interface=UniFi
dst-port=8888 log=no log-prefix=“”
FOR IP FILTER
51 chain=forward action=accept connection-nat-state=dstnat in-interface=UniFi log=no log-prefix=“”
FYI UniFi interface is PPPoE client dial up, dynamic public IP.
Had been tried this https://forum.mikrotik.com/viewtopic.php?t=179343
3 rules been applied and its still not working. Hope everyone can enlighten me.
Thank you.
