Need help! for routing config!
Hello!
Can anyone help me with routing config! I want to do Point to Point link!
(Not in WDS mode.) But by bridging the interfaces! I have 2x MT RB112 with lvl 4 license. (TRUE BRIDGE) Is that possible with RB112?
My Netw. setup:
BSD makes DHCP and assigns needed speed limits for clients-s
BSD: 192.168.67.31
GW:192.168.1.1
1.RB112 APBridge: eth1 192.168.1.120
wlan1 10.1.0.1/24
2.RB112 Station: wlan1 10.1.0.2/24
eth1 192.168.1.121
DHCP Clients 1-192.168.1.140
2-192.168.1.145
and so on!
I see both sides Mac addr. But no dataflow! So i think problems with routing! can anyone help me! Need to get that work before Monday! :frowning:
msn: info@sinumaja.net
You say that you need help for a routing config, but in the next sentence you do state that you want to do bridging. So what DO actually you want to do?
May I assume you want to create a transparent point-to-point bridge with one side as AP, the other as station?
You cannot bridge a station interface without using WDS. In the upcoming version 3.0 of RouterOS (which is in beta right now) you will be able to bridge a station-interface (by using mac-cloning).
But the 802.11 standards don’t allow for bridging without using WDS or doing tricks like MAC cloning/MAC-NAT.
So right now (and version 3.0 won’t be out till Monday :wink: ) you can EITHER route your p2p connection, or you have to use WDS (or EoIP) to create a bridge…
Best regards,
Christian Meis
Cmit thanx for your quick reply!
Ok then Can´t bridge :frowning:
But then i need to do some routes in AP and station mode!
I never use WDS and EoIP tunnels (slowers speed)!
Ok I can setup working link but routing is my weak point and I attend to learn it! So dont judge me if Im with stupid! :wink:
This is my first MT product I ever used! I have readed the manuals many time but more I read then more Im confused!
Can then somebody explain it!
If you wanted to route traffic from your station to the gateway you would have to setup a route in all the devices from point a to c.
So if you have your station wanting to pass traffic from your computer to the ap you would need a route their first.
Example:
192.168.1.140 to 10.1.0.1
Then you would need a route on your ap to your gateway…
Example:
192.168.1.120 to 192.168.67.31
Then just make sure your route on your gateway is set correct.
This is a rough example and might need to be changed.
Matt
Ok lets assume that I have:GW 192.168.1.1
  1. RB112 AP lan interface IP=192.168.1.120/24
    wlan interface IP=10.1.0.1/24
[admin@MikroTik] ip address> print
ADDRESS NETWORK BROADCAST INTERFACE
0 10.1.0.1/24 10.1.0.0 10.1.0.255 wifi
1 192.168.1.120/24 192.168.1.0 192.168.1.255 lan
C - connect, S - static, r - rip, b - bgp, o - ospf
DST-ADDRESS PREF-SRC G GATEWAY DISTANCE INTERFACE
0 A S 10.1.0.1/32 r 192.168.1.120 lan
1 ADC 10.1.0.0/24 10.1.0.1 wifi
2 A S 192.168.1.120/32 r 192.168.1.1 lan
3 ADC 192.168.1.0/24 192.168.1.120 lan
on station:
0 10.1.0.2/24 10.1.0.0 10.1.0.255 wifi
1 192.168.1.121/24 192.168.1.0 192.168.1.255 lan
[admin@MikroTik] ip route> print
0 A S 10.1.0.2/32 r 10.1.0.1 wifi
1 ADC 10.1.0.0/24 10.1.0.2 wifi
2 A S 192.168.1.121/32 r 10.1.0.2 wifi
3 A S 192.168.1.140/32 10.1.0.1 wifi
4 ADC 192.168.1.0/24 192.168.1.121 lan
Whats wrong? I can ping on (AP) my GW, LAN, WIFI and STATION WIFI IP-s
On (Station) I can ping AP WIFI int.
Your problem is that both the AP and the station are using 192.168.1.0/24 on their LAN interfaces. You need to use different, non-overlapping networks on the AP and the station(s) otherwise routing will not be possible.
–Tom
Can anyone assist via MSN? :question:
info@sinumaja.net
