This is my 1st Post and hope will get some help.
I have 2 WAN connection and 2 LAN Network setup Code below. What i want to do is LAN-1 User will get WAN-1 Access and LAN-2 Will get WAN-2. But only LAN-1 user getting internet but LAN-2 not.
set [ find default-name=ether5 ] name=FLOOR-5
set [ find default-name=ether3 ] name=Local
set [ find default-name=ether4 ] master-port=Local name=Local-4
set [ find default-name=ether1 ] name=WAN1
set [ find default-name=ether2 ] name=WAN2
/ip neighbor discovery
set FLOOR-5 comment="PORT-5 FOR 5TH FLOOR"
set Local comment="PORT-3"
set Local-4 comment="PORT-4, SLAVE OF PORT-3"
set WAN1 comment="PORT-1"
set WAN2 comment="PORT-2"
add address=123.123.123.123/28 interface=WAN1 network=123.123.123.48
add address=444.444.444.444/30 interface=WAN2 network=444.444.444.68
add address=192.168.0.1/24 interface=Local network=192.168.0.0
add address=192.168.1.1/24 interface=FLOOR-5 network=192.168.1.0
add name=DHCP_POOL_1 ranges=192.168.0.2-192.168.0.254
add name=DHCP_POOL_2 ranges=192.168.1.2-192.168.1.254
add address-pool=DHCP_POOL_1 disabled=no interface=Local name=VINRACK_DHCP_1
add address-pool=DHCP_POOL_2 disabled=no interface=FLOOR-5 name=VINRACK_DHCP_2
add address=192.168.0.0/24 dns-server=202.164.215.3,8.8.8.8 gateway=192.168.0.1
add address=192.168.1.0/24 dns-server=180.234.0.193,180.234.8.193 gateway=192.168.1.1
set allow-remote-requests=yes cache-size=5000KiB max-udp-packet-size=512 servers=8.8.8.8
/ip firewall mangle
add action=mark-connection chain=input in-interface=WAN1 new-connection-mark=WAN1_CONN passthrough=no
add action=mark-connection chain=input in-interface=WAN2 new-connection-mark=WAN2_CONN passthrough=no
add action=mark-routing chain=output connection-mark=WAN1_CONN new-routing-mark=TO_WAN1 passthrough=no
add action=mark-routing chain=output connection-mark=WAN2_CONN new-routing-mark=TO_WAN2 passthrough=no
add chain=prerouting dst-address=123.123.123.0/28 in-interface=Local
add chain=prerouting dst-address=444.444.444.0/30 in-interface=FLOOR-5
add action=mark-routing chain=prerouting connection-mark=WAN1_CONN in-interface=Local new-routing-mark=TO_WAN1
add action=mark-routing chain=prerouting connection-mark=WAN2_CONN in-interface=FLOOR-5 new-routing-mark=TO_WAN2
add action=mark-connection chain=prerouting dst-address-type=!local in-interface=Local new-connection-mark=WAN1_CONN
add action=mark-connection chain=prerouting dst-address-type=!local in-interface=FLOOR-5 new-connection-mark=WAN2_CONN
add action=masquerade chain=srcnat out-interface=WAN1
add action=masquerade chain=srcnat out-interface=WAN2
add check-gateway=ping distance=1 gateway=123.123.123.49 routing-mark=TO_WAN1
add check-gateway=ping distance=1 gateway=444.444.444.69 routing-mark=TO_WAN2
add check-gateway=ping distance=2 gateway=444.444.444.69
Will some one please advice with code what i am missing. coz im nutts in this
