Need help for setting up radius on second WLAN
Hi all,
currently running 6.31 on mikrotik wlan router.
Just wondering what are the missing steps to run two wlans like this:
-one with WPA2 (currently already running)
-one, already created as virtualAP , which I would like running withsecurity profile 802.1x. I can do radius on local wired network microserver or on mikrotik itself, does not matter.
I seem not able to find a good guide on the entire internet. Can you please support me?
What is the problem that you are having? What is not working?
The way you describe it it should work
I would need to create security profile but see only open/wep/WPA/wpa2
How do I go forward?
Bump!
