I just bought this router RB751U-2HnD and try configure as hotspot using hotspot wizard and completed but the text are in read, when I connected to the hotspot network, my laptop just connected to internet without popup login page. Please help me cause I already try many times and try other ether port still unsaccesfull. I also read many tutorial found on the net to setup the hotspot but still fail.
Hope someone can help me to solve this problem, I’m newbie here.
Thanks…
Finally I got the solution…after so many try and error
Problem is from routeros default configuration :
#| ether1 is renamed to ether1-gateway
#| DHCP client and masquerade is set on ether1-gateway
#| ether2 is renamed to ether2-master-local and configured as switch master port for ether3-ether5
#| ether2-master-local and wlan1 are bridged - this the culprit…
#| wireless is set as access point in 2412MHz using both chains and extension channel enabled.
#| IP address 192.168.88.1/24 and DHCP server is set on bridge interface
#| DHCP servers address pool is 192.168.88.10-192.168.88.254
delete the bridge ether2-master-local and wlan1
then configure the hotspot as tutorial… no more red mark (error)
