How can i restart automaticly Scripts after reboot.
After a reboot all my Scripts doesn`t run.
THX
THX
If they are schduled scripts on an RB532, then you need to set your ‘start-date’ to a date befor the RB default stratup…
I use 1970…
you can also use start-time=startup on schaduler
That too… forgot about that new addition…
