Need Help in My First PTP Link
Hello Everyone,
I am starting WISP in my local area,I want to put my first PTP link through wireless,I am newbie at mikrotik and wireless networking.,So please suggest me device for PTP link and setting to use in it,I mean protocol and anything other.The distance is 9 KM between both area through air.
Should I use RBSXTG-5PHND.
Use SEXTANT G 5HPnD for better result.
How to calculate hight and distance through GPS’s latlong?
Try this
http://www.movable-type.co.uk/scripts/latlong.html
Do you mean sxt g 5 hpnd sar2
GO this link
http://routerboard.com/RBSEXTANTG5HPnD
can I suggest you have a look at two links below.
http://www.ve2dbe.com/rmonline.html
and
http://shop.duxtel.com.au/article_info.php?articles_id=53
The first link will give you all sorts of good path profile info. The second link allows you to choose different mikrotik units and calculates expected data rates.
9km is a reasonable distance so don’t expect too much.
