Need help in point to multipoint network
We are going to do a Wi-Fi zone on a specific road, we need help in configuration of back-haul 5GHz point to multi-point network. For Wi-Fi network we are using 2.4GHz AP’s. We will be installing both the AP’s on the poles installed on side of the road, Please check the attached image for better understanding.
We need to make a mesh Network or a point to point network in continuous mode.
According to image: AP1 need to be connected to AP2 and AP2 need to be connected to AP3 and it should go on…additionally if we consider a Mesh network AP1 should connect to AP3 aswell and AP2 should connect to AP4 aswell and so on…
Please let me know how to configure the same with SKT SA5 which is a 90 degree Sector AP.
Thanks in Advance.
Omkar :slight_smile:
