i’m an absolutly beginner for Mikrotik and RouterOS. I have an Router with one Wlan and one Lan. On the Lan is an other Router (TP-LINK) connected. My PC has the wlanIP 10.255.255.2, Mikrotik-WlanIP 10.255.255.1, Mikrotik-LanIP 192.168.1.1.
I connect via Wlan to Microtik, can ping Wlan and Lan but not the TP-LINK router (IP 100.100.100.1)on ether1. How must look generally a Route between two different networks.
It’s great if someone can me explain it.
I think you need to explain your infrastructure a bit more in detail and what it is that you want to do. It can be very problematic with a router-after-router. Are you intending to have more networks on the same LAN? - or is your intention just to connect everything to the same network e.g. 192.168.0.0/24?
Hallo
IP ether1 Mikrotik: 192.168.1.1
IP other Router on ether1 from Mikrotik: 100.100.100.1
my Problem is, if on ether1 from Mikrotik connected a Router with other Subnet, then no connect to this Router. If the Router in same Net (like IP 192.168.1.2) then i have connect. Generally is the my Question, is possible create a Route in Mikrotik between two subnet. I think the Mikrotik can it, but i don’t know what i write in the Routingtable.
