Need help installing routeros directly to SD card
Sveiks,
I want to load routeros on a watchguard M200 firewall.
I have a USB card reader and inserted the 8Gb SD card out of the watchguard into the card reader and attached it to a win10 pc.
I formatted the card Fat32 and can see the card in win10 as drive E.
I have downloaded the latest stable release of netinstall 6.47.1 and also the arm version of the routeros.
issue is in netinstall, i can see the USB card reader drive E, but when i select it, the routeros npk file dissapeasr from below.
and vice versa, if i load up the routeros in netinstall and select it , then try and select USB drive E from top part of the window, then routeros dissapears. Not sure why?
I dont knwo how to do netinstall via network cable onto watchguard directly, so was going to try the USB SD card reader directly from a win10 as i read that it can be doen that way?
Any suggestions would be appreciated.
Eriks from Australia
