guys, i have one more question.
how do i make Lan Port 3,4,5 and 6 be able to ping each other? and how do i enable hotspot on Port 3,4,5,6?
please check this config for hotspot.
Hotspot Config on Lan Port 3
[admin@MikroTik] /ip hotspot> setup
Select interface to run HotSpot on
hotspot interface: ether3
Set HotSpot address for interface
local address of network: 10.10.1.1/24
masquerade network: yes
Set pool for HotSpot addresses
address pool of network: 10.10.1.1-10.10.1.254
Select hotspot SSL certificate
select certificate: none
Select SMTP server
ip address of smtp server: 0.0.0.0
Setup DNS configuration
dns servers: 10.10.1.1
DNS name of local hotspot server
dns name: myhotspot 3
Create local hotspot user
name of local hotspot user: admin
password for the user:
Hotspot Config on Lan Port 4
local address of network: 10.10.2.1/24
address pool of network: 10.10.2.1-10.10.2.254
Select SMTP server
dns servers: 10.10.2.1
dns name: myhotspot 4
