NEED HELP ON - WebFig v5.2
Hello!
I have a situation in which the program is a VMware virtual machine to which is to build a website. to view this site I connect to a VPN (virtual private network).
If you can please help me configure the router so that you can connect to the website without using a VPN. So as to make it publicly available?
Look forward to your response.
You mean you have a VMware system running inside your LAN, and you want to be able to connect to this system remotely, through the router?
You probably need a DST-NAT rule for redirection. Does this program use a specific port ? You will need to know the destination IP and port to make a DST-NAT rule.
You Mean You Have a VMware system running inside your LAN, and you want to be ABLE to connect to this system remotely, through the router?
Yes VMware running inside my LAN.
when I have hooked up a VPN using the IP address of 192.168.99.13. server port is 80
You are from the Latvia? I can speak Latvian? :slight_smile:
Jā, jums tad vajag rūterī šādu DST-NAT ierakstu:
/ip firewall nat add chain=dstnat dst-port=80 protocol=tcp action=dst-nat to-addresses=192.168.99.13 to-port=80
Kad ierakstīsiet šo, atverot browserī rūtera publisko IP, jūs automātiski tiktiet pārsūtīts uz to VMware ierīci, bez vajadzības pēc VPN.
Te ir arī citi piemēri: http://wiki.mikrotik.com/wiki/Manual:IP/Firewall/NAT#Destination_NAT
Man ar rūteriem tā švaki iet. Varbūt variet sīkāk aprakstīt kas un kā jādara, lai man nenojūk viss?
copy:
paste rūtera komandrindā (“new terminal”)
viss
Paldies, mēģināšu :slight_smile:
Es iegāju
IP ->Firewall → NAT → Add new
un pēc dotā teksta aizpildīju attiecīgos lauciņus.
Pēc tam ievadot caur kādu adresi es varēšu piekļūt mājaslapai?
Man tagad ir tā, ka es ievadu pārlūkprogrammā VPN adresi un man atver manu mājaslapu, bet man vairs neiet VPN. nevar savienoties. tas ir tapēc, ka tagad sanāk pārmet no vpn uz Vmware ip adresi?
Man vajadzētu lai ir tā, ka ievadu IP un atveras mājaslapa un tajā pašā laikā es varu arī izmantot VPN. Tur kaut ko savādāk vajag likt?
ir uztaisīts tā, ka tikai browsera pieslēgumu pārsūta tālāk (ports 80). VPN nav ietekmēts. kāpēc tas neiet, grūti spriest.
Ja VPN arī ir 80 ports, tad tas varētu būt pie vainas?
jā protams. bet parasti VPN neizmanto 80 portu.
Es šobrīd nevaru piekļūt rūterim. Kad tikšu klāt tad paskatīšos kas un kā. varbūt vēl ir kāds variants?
Varbūt es neīsto ip adresi liku? kad pieslēdzos Vmware es slēdzos klāt VPN un tad caur wmvare klinetu slēdzos klāt IP 192.168.99.156
Bet mājaslapa, kas uztādīta uz wmvares iet uz IP 192.168.99.13, bet VPN adrese ir 159.148.29.156.
most probably you forgot to enter destination port that has to be forwarded to some internal port, as result all traffic is forwarded to your virtual guest. If you can login into that (vmware guest) you coulc log from there into the router and correct the rule you just created. Just note you have to have both set - dst-port and to-port.
Vārdsakot es lieku visu caur šo logu. Es par tiem portiem maz ko saprotu kur kas jāliek
vajadzēja sekot norādijumiem. ja neielikāt portus, tāpēc arī nekas nestrādā. visas vērtības jūsu bildē ir nepareizajās vietās. lūdzu atveriet new terminal un ierakstiet to ko biju devis augstāk.
Biju salicis portus. Man tad nestrādāja VPN. Man rūteris izmanto 80 portu.
