I’ve posted this thread a few days ago (I’ll repost the text below): http://forum.mikrotik.com/t/4-km-p2p-throughput-problems-qrt-5-ac/107002/1
Right now I’ve tried everything to improve the throughput of the link but I’m not getting any good results. I need someone to log into my computer using TeamViewer and play with the settings of both devices in the link and help me figure out the best setting to achieve better speeds. You will be rewarded for your time. If you’re interested in helping please reply with your email or contant details.
Thank you.
"I a QRT 5 ac set up at each point, the distance is around 4.2km and the signal strength hovers around -59 and -63 depending on the type of protocol chosen and channel width and so on. I’ve tried 802.11 and it’s slightly less stable than nstreme (weaker signal and speed unstable), and NV2 doesn’t connect most of the time.
I have a 200mbps connection at point A that I’m trying to send to point B. The highest I could get was around 55mbps when the signal is at -59, and barely 25mbps when it’s just slightly higher around -63.
Here are a bunch of images of my settings, please let me know what I could do to improve the throughput, and what other settings you’d like to see:
