Currently using a MikroTik RB4011iGS+5HacQ2HnD router, with an ISP-supplied cable modem that grants Internet access (courtesy of Shaw Communications).
I need more WiFi coverage for the house, so I’m hoping some folks here can chime in and recommend a MikroTik device that would pair well with the 4011 as a wireless access point.
And just to be 100% clear, this is the path I want for wireless client traffic (the AP and the 4011 router will be connected to each other via Ethernet cable):
Have both wAP ac and cAP ac, love them. The wAP ac has 3x3 MU-MIMO while the cAP ac has 2x2 MU-MIMO (on the 5GHz radio). Most clients support 2x2 MU-MIMO, but if it supports 3x3 MU-MIMO it will perform better.
Better WiFi, slower CPU. So if you want it as an AP/basic wired switch, the AC is the better choice, if you want to use it as a router with integrated (somewhat less capable) WiFi and switch the AC2 is better. In your case, the hAP ac is probably the one to go for, as it is the more capable AP.
Okay, so I picked the hAP AC, and it just arrived.
I have a vague understanding of how I’d go about setting it up, but I could use some help with a few particular details:
I want to be able to “see” both the 4011 and the hAP AC (and all connected clients) via the main 4011 Winbox panel (so I don’t need to constantly log back and forth between them). Would I need to set up a VLAN to accomplish this?
Assuming the above is possible, how would I go about avoiding double NAT problems?
The 4011 is currently set to use DHCP, with IP reservations for most of the “permanent” clients. Will this cause problems for the aforementioned details?
