anyone can tell me how to setup a DHCP server & client…? in specific plis…
i’ve read the manual 10 times maybe more…but i still cant make the client connect…
for the information=
i used the 2.9.27 version
i have 2 ethernet
1 for local → 10.10.0.0/16
1 for internet
all with a static ip…
so i want to make 4 computer with a dchp and 4 computer with a static (the static is already running)…
and i want the dhcp & static to connect to internet
and can anybody configure radius…?
where can i find free radius server
thx
connect through winbox to your router and go to ip ->DHCP server and then hit Setup button, and you will be able to complete the configuretaios as this wizard will gauide you through configuration and ask whatever is neded.
then you can study what and where was set and try do do it by yourself (but i do not recomend that) maybe better jsut adjust some thigs you missed.
oh and disable your current config that is not working.
forgot to add if you use console for configurations then this is the command to invoke
I thing 'TEN' times to make running networks as IP: Static, Dynamic, DHCP [Dynamic Host Configuration Protocol] than AAA [Radius-Server] is not enought to do it, or cross easy way just attanding to MUM event if available, here I am almost every night read manual since last year ago until now is not enought to make Mikrotik 'advance'.
here I am running Static, Dynamic, and DHCP [Hotspot], PPPoE centralize AAA with Mikrotik 'User Manager' as Radius Server everything on one network line.
You can setup Hotspot is better as you said in this forum.
