Need Help PPP
Good Day
I am having a unique problem and i hope there is someone who can help me out.
I have an user that needs to VPN into my network and only have access to 1 IP(192.xxx.x.x) address where the VM is.
The user is not allowed any access to my network only that 1 IP address.Kind of like an DMZ as far as i understand.
Thank you very much
I Hope i explained it correct.
Regards
Hey. As I can see, you using NAT and also you have global IP address on your WAN interface. If so, then you just need to create one destination nat rule to this single host with /32 mask. But don’t forget to configure your VM from inside in order to deny any conenctions from VM source IP to your LAN devices except direction your user need to.
