Need help routing between subnets
-I would like to learn routing between subnets, and pratice VPN on it
Here is the diagram for my little network. Both Mikrotik link by 192.168.3.X
-PC1 which connect to MTK1 eth2, I wish to ping MTK2 eth2 & eth3
I added a static route 192.168.0.0/21 GW 192.168.3.1
but still could not ping 192.168.4.1 and 192.168.6.1. Eventually I would like to ping the 2 VMs
in ESXi Server.
-MTK2, I added static route 192.168.2.0/24 GW 192.168.3.1
Terminal, I can ping 192.168.2.1 but can not ping 192.168.2.50 (PC1)
-Can someone help me with the routings?
-In my log, someone try to SSH with various usernames..In IP > Services, I disable ssh port 22
would that help? How can I allow SSH to the router with specific IPs
Thanks!
If you would like to ping pc1 and pc2 from the vm or mt 2. You will need to give ether1 on mt2 the ip of 192.168.3.2/24. Then, you add the static route 192.168.2.0/24 with gateway 192.168.3.1. This will allow you to add the settings to mt 1 correctly. Your first question saying you want to ping ether 2 and 3 of the mt 2 from pc1. You will need to add a static route in mt 1. 192.168.4.0/24 gateway 192.168.3.2 and 192.168.6.0/24 gateway 192.168.3.2. This should allow you to ping the mt2 and the 2 vms from pc1 and pc2.
Also to only allow certain ips to ssh into your mikrotik there is multiple ways of doing it, but the easiest is going to IP > Services. Add your ips into the available from box.
If you need anything else don’t hesitate to email me.
Thanks!! I did ask u suggest
MTK1
IP > Routes
AS 192.168.4.0/24 Gateway: 192.168.3.2
AS 192.168.6.0/24 Gateway: 192.168.3.2
MTK2
IP > Addresses
IP: 192.168.3.2/24, Network: 192.168.3.0, Interface: eth1 - WAN
IP > Routes
AS 0.0.0.0/0 Gateway: 192.168.3.1
AS 192.168.2.0/24 Gateway: 192.168.3.1
From MTK1 Terminal, I can ping 192.168.4.1, 192.168.4.100 (ESXi NIC1), 192.168.6.1
From MTK2 Terminal, I can ping 192.168.2.1, but I can’t ping PC1, which now IP 192.168.2.253 (DHCP).. There are no Firewall NAT rule..I also try disable 0.0.0.0/0 but nothing..Any idea?
On my ESXi 4.01 Server..the management port is on NIC1. After I added NIC2, I would like to set an IP to it. I add vSwitch1, in Vmkernel I added IP 192.168.6.100, SM: 255.255.255.0 but I can’t set Gateway 192.168.6.1. I would like NIC1 connect to 1 router, then NIC2 connect to another router..Each NIC have different subnet..Is that possible since ESXi only allow 1 gateway. I read may need an VLan switch such as RB250GS? How would I configure it?
-For ESXi I figure out how to assign different subnet to each NIC
-For PC1 after I allow ICMP traffic in Win7 firewall, I am able to ping it from MTK2
Question: I have 3 sites using PPoE. They will be using Mikrotik routers. They would like connect and see each other’s share+network..Which VPN method u guys suggest??
Ex: just PPtP ?
EoIP ?
IPIP w/ IPSec?
Thanks!
Hey, I would suggest not setting up a vlan. Could you output your rules here or email them to me. You should have have a route set up so you can ping 192.168.2.253 from mk2 would be reachable from gateway 192.168.3.1 ether3 on mk1. Am I misunderstanding you?
Thanks Devin..it was Win7 firewall that stop the ICMP..It’s ok now.
Hehe. Cool good deal glad that worked for ya.
