Need Help Script for sim swap
Good morning,
i would need your help to configure sim swap script when internet is down on the sim A in use.
It should check the ping at 8.8.8.8
in case of negative result, change to sim B.
in case of negative result, change back to sim A.
someone would be kind enough to write me the code, i don’t understand much about programming
