Need help setting DHCP server VLAN
Hi all, i’m new to Mikrotik and need some help with my configuration, i need to setup a DHCP server on a VLAN 11 so my ISP router can get an IP for the VOIP (internet works perfect on VLAN 20), but when i create another DHCP server i get the error of “no IP address on interface”
# 2025-02-08 14:03:49 by RouterOS 7.17.1
# software id = PLE9-LR9F
# model = C53UiG+5HPaxD2HPaxD
# serial number = XXXXXXXXX
add admin-mac=XXXXXXXXXXXXXX auto-mac=no comment=defconf name=bridge
add comment="Docker DNS AdGuard" name=contenedor-adguard
/interface wifi
set [ find default-name=wifi1 ] channel.skip-dfs-channels=10min-cac \
    configuration.mode=ap .ssid=MikroTik-2D2097 \
    security.authentication-types=wpa2-psk,wpa3-psk .ft=yes .ft-over-ds=yes
set [ find default-name=wifi2 ] channel.skip-dfs-channels=10min-cac \
    configuration.country=Spain .mode=ap .ssid=Mikrotik disabled=no \
/interface veth
add address=172.19.0.2/24 gateway=172.19.0.1 gateway6="" name=veth1
/interface vlan
add interface=ether1 name=vlan-internet vlan-id=20
add comment="VLAN 11 VOIP DIGI" interface=ether5 name=vlan_VOIP_DIGI vlan-id=\
    11
add interface=ether5 name=vlan_router_digi vlan-id=20
/disk
set usb1 media-interface=bridge media-sharing=yes smb-sharing=yes
set usb2 media-interface=bridge media-sharing=yes smb-sharing=yes
/interface pppoe-client
add add-default-route=yes disabled=no interface=vlan-internet name=\
    pppoe-internet user=XXXXXXXXX
add comment=defconf name=WAN
add comment=defconf name=LAN
add comment="Pool PPPoE DIGI" name=pool_pppoe_server ranges=\
    10.0.1.200-10.0.1.250
add comment="Pool de IPs para VOIP DIGI" name=pool-IPv4_RouterDIGIVoIP \
    ranges=100.111.120.10-100.111.120.15
add address-pool=default-dhcp interface=bridge name=defconf
# No IP address on interface
add address-pool=pool-IPv4_RouterDIGIVoIP authoritative=after-2sec-delay \
    comment="DHCP VOIP DIGI" interface=vlan_VOIP_DIGI lease-time=3d30m name=\
    dhcp_DIGIVoIP
/ppp profile
add local-address=10.0.1.1 name=pppoe_server_digi remote-address=\
    pool_pppoe_server
/container
add interface=veth1 logging=yes root-dir=usb2/etc start-on-boot=yes workdir=\
    /opt/adguardhome/work
/container config
set registry-url=https://registry-1.docker.io tmpdir=/adguard
/disk settings
set auto-media-interface=bridge auto-media-sharing=yes auto-smb-sharing=yes
add bridge=bridge comment=defconf interface=wifi1
add bridge=bridge comment=defconf interface=wifi2
add bridge=contenedor-adguard comment="AdGuard DNS" interface=veth1
add interface=pppoe-internet list=WAN
/interface pppoe-server server
add authentication=chap,mschap1,mschap2 default-profile=pppoe_server_digi \
    disabled=no interface=vlan_router_digi service-name=servicio_router_digi
    192.168.88.0
add address=172.19.0.1/24 comment="IP DNS AdGuard" interface=\
    contenedor-adguard network=172.19.0.0
/ip dhcp-client
/ip dhcp-server lease
add address=192.168.88.254 client-id=XXXXXXXXXXXX mac-address=\
    00:11:32:80:9A:34 server=defconf
add address=192.168.88.251 client-id=XXXXXXXXXXXX mac-address=\
    FC:34:97:91:63:90 server=defconf
add address=192.168.88.241 client-id=XXXXXXXXXXXX mac-address=\
    FC:34:97:76:4B:40 server=defconf
add address=192.168.88.240 client-id=XXXXXXXXXXXX mac-address=\
    FC:34:97:B1:E2:D0 server=defconf
add address=192.168.88.0/24 comment="Servidor DHCP con DNS AdGuard" \
    dns-server=172.19.0.2 gateway=192.168.88.1
set allow-remote-requests=yes cache-size=10048KiB servers=\
    1.1.1.1,8.8.8.8,8.8.4.4
/ip dns static
add address=192.168.88.1 comment=defconf name=router.lan type=A
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
add action=dst-nat chain=dstnat comment=Torrent dst-port=XXXXX \
    in-interface-list=WAN protocol=tcp to-addresses=192.168.88.254 to-ports=\
    XXXXX
    in-interface-list=WAN protocol=udp to-addresses=192.168.88.254 to-ports=\
    XXXXX
add action=masquerade chain=srcnat comment="Masquerade VOIP DIGI" \
    src-address=100.111.120.0/24
/ip hotspot profile
/ipv6 firewall address-list
/ipv6 firewall filter
    invalid
    icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" \
    dst-port=33434-33534 protocol=udp
    udp src-address=fe80::/10
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
    icmpv6
    500,4500 protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
/ppp secret
add name=XXXXXXXXXXXX profile=pppoe_server_digi service=pppoe
/system clock
set time-zone-name=Europe/Madrid
/system note
set show-at-login=no
/system ntp client
set enabled=yes
/system ntp client servers
add address=0.es.pool.ntp.org
add address=1.es.pool.ntp.org
/system routerboard mode-button
set enabled=yes on-event=dark-mode
/system routerboard wps-button
set enabled=yes on-event=wps-accept
/system script
add comment=defconf dont-require-permissions=no name=dark-mode owner=*sys \
    policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon \
    source="\r\
    \n   :if ([system leds settings get all-leds-off] = \"never\") do={\r\
    \n     /system leds settings set all-leds-off=immediate \r\
    \n   } else={\r\
    \n     /system leds settings set all-leds-off=never \r\
    \n   }\r\
    \n "
add comment=defconf dont-require-permissions=no name=wps-accept owner=*sys \
    source="\r\
    \n   :foreach iface in=[/interface/wifi find where (configuration.mode=\"a\
    p\" && disabled=no)] do={\r\
    \n     /interface/wifi wps-push-button \$iface;}\r\
    \n "
/tool mac-server
/tool mac-server mac-winbox
Thank you
Please have a very good look at this great topic, it describes the configuration of VLAN’s in multiple situations:
First things I notice on your config:
  • no VLAN filtering on bridge
  • multiple bridges
Single bridge for all data vlans as per http://forum.mikrotik.com/t/using-routeros-to-vlan-your-network/126489/1
The single bridge will also be the interface for both ISP vlans.
These vlans however will not get any dhcp, Ip address etc…
The WAN Vlan will get terminated at either the IP DHCP client settings or the PPPOE settings etc. and thus will not be seen on any /interface bridge vlan settings.
The VOIP Vlan will simple get passed, transparently, from incoming port to VOIP device on port X of router or possibly passed down a trunk port to a switch and then to VOIP device.
If the VOIP device cannot read tagged data, the traffic as last step is untagged to the VOIP device.
At least thats my limited understanding.
