i have ADSL connection.
my network config :
– ADSL Modem (Bridging mode ) —> Wireless LAN (Bridge) —> Mikrotik.
i try PPPoe with Mikrotik, but still cannot connected.
can some one help me, how can i do to solve this ?
my network config :
did you tried to do that without using wireless bridge?
not yet.
because .. distance my ADSL modem and mikrotik= 4 km (far)
Use EoIP tunnel.
I have done such a thing. ADSL modem - Bridge - Mikrotik
There were no problem.Disable all DHCP servers in adsl modem and bridge devices.
i have config : DHCP Disable ( ADSL Mdm ) , ADSL Modem on bridge mode.
i want to use PPP (PPPoE) on Mikrotik to dial ISP.
can u give me example
can u give me example ?
SSD:
bintang:
my network config :– ADSL Modem (Bridging mode ) —> Wireless LAN (Bridge) —> Mikrotik.
Use EoIP tunnel.
I think problem is in the Bridge mode.
http://forum.mikrotik.com/t/can-i-connect-to-an-adsl-modem-via-pppoe/22963/1
Try to do that without wi-fi, probably it won’t connect.
i have try with this concept:
–ADSL Modem (bridge) —>WIFI (Bridge) — Desktop PC (with PPPoE connection ).
The connection success.
when Desktop PC changed with Routerboard 532A (2.9.51) , connection not success.
dialing … , dialing …, terminated…
dialing …
any one can solve this problem…
Wireless ADSL Modem(Bridge) ----> Mikrotik WAN (use AR5414A for pppoe-out).OK…?
why if i use AR5413 ?
no difference
