I get my internet via a Wireless ISP thru a Groove 52 AC. I am working with the guys in the ISP to keep the network tuned up. They had not expected to use any Mikrotik devices so I am learning this all on the fly. I want to use The Dude to monitor the network. I am using a RB750Gr3 to run The Dude server on, and it is working. Still getting that configured, but it is progressing. But originally I was using a rb952ui-5ac2nd because I want the wireless in the house. I tried setting up the RB750 to be the “Router” doing all the DHCP and the like, with the RB952 only providing the wireless portion of the network, but still using the RB750 to do the DHCP. I thought it was working well until I started other wireless devices. They did not work. Some do and some don’t. I have tried various configurations on the RB952, but nothing changes. What would be the best way to configure these two devices to work together so that I can use The Dude to monitor both the ISP’s network and my own, and have wireless networking in the home? Monitoring the ISP’s network and having my own wireless network is most important. Any help or advice would be appreciated.
Please post a config for the problem device.
What are you using dude to monitor exactly? Your ISPs network? I didn’t quite understand that bit. You don’t really have a network to monitor?
Thanks for your attempt to help me. I found my problem. I keep trying to make a major change to a Mikrotik Device and fail miserably. I just reset the configuration and did it from scratch and it worked perfectly.
