So basically you want to have eth1 and eth2 switched as ISP “lan” and add to that a dedicated SSID on wlan. On the other hand you’d like to have eth3, eth4 and eth5 switched as LAN and add to that its own SSID?
Prior to reconfiguration, I suggest you to
- make backup of device and copy backup file off device
- export configuration executing /export file=myexport.txt and copy text export file off device
- upgrade device to latest long-term (6.46.8 at this moment, stay away from “stable” version 6.48 as it seems to have a few problems), including routerboot (execute /system routerboard upgrade after it reboots to ROS 6.46.8). This will give you the latest-and-greatest default setup to work with (you’ll need it).
Something like this … in two parts.
Part 1 - configuration fo ethernet, VLANs. Easy to lock self out during this part:
# ISP: VLAN 100
# LAN: VLAN 200
add name=bridge
add bridge=bridge interface=ether1
add bridge=bridge interface=ether2
add bridge=bridge interface=ether3
add bridge=bridge interface=ether4
add bridge=bridge interface=ether5
add bridge=bridge interface=wlan1
add bridge=bridge interface=wlan2
/interface vlan
add interface=bridge name=vlan_ISP vlan-id=100
add interface=bridge name=vlan_LAN vlan-id=200
add name=WAN
add name=LAN
add list=WAN interface=ether1 # not really needed, but just in case
add list=WAN interface=ether2 # not really needed, but just in case
add list=WAN interface=vlan-ISP
add list=LAN interface=ether3 # not really needed, but just in case
add list=LAN interface=ether4 # not really needed, but just in case
add list=LAN interface=ether5 # not really needed, but just in case
add list=LAN interface=vlan-LAN
# Secure management access via MAC
/tool mac-server
/tool mac-server mac-winbox
set 0 default-vlan-id=100 vlan-header=always-strip vlan-mode=secure # eth1
set 1 default-vlan-id=100 vlan-header=always-strip vlan-mode=secure # eth2
# special warning for the next 3 lines!!!!! (see text below)
set 2 default-vlan-id=200 vlan-header=always-strip vlan-mode=secure # eth3
set 3 default-vlan-id=200 vlan-header=always-strip vlan-mode=secure # eth4
set 4 default-vlan-id=200 vlan-header=always-strip vlan-mode=secure # eth5
add switch=switch1 independent-learning=yes ports=switch1-cpu,ether1,ether2 vlan-id=100
add switch=switch1 independent-learning=yes ports=switch1-cpu,ether3,ether4,ether5 vlan-id=200
# special warning for the next line!!!!! (see text below)
set 5 vlan-mode=secure # switch1-cpu
Warning about setting vlan-mode on switch1-cpu port and on LAN-to-be ports: you’ll probably loose access to the device at this point, but you should be able to re-connect. If not, you’ll have to perform factory reset using the button procedure.
Part 2 - configuration of the rest (wireless, IP, …):
# set up two security profiles, one for LAN wifi and the other for ISP wifi
/interface wireless
set [ find name=wlan1 ] security-profile=<LAN security profile> ssid=<LAN SSID> vlan-mode=use-tag vlan-id=200 # add other wireless settings
add master-interface=wlan1 name=wlan2 security-profile=<ISP security profile> ssid=<ISP SSID> vlan-mode=use-tag vlan-id=100 # optionally add other settings for virtual AP
add list=LAN interface=wlan1 # probably not needed, but just in case
add list=WAN interface=wlan2 # probably not needed, but just in case
# add WAN configuration, e.g. DHCP client, to vlan-ISP interface
/ip dhcp-client interface=vlan-ISP
# add LAN configuration, e.g. static IP address, DHCP server, to vlan-LAN interface
add address=192.168.88.1/24 interface=vlan-LAN network=192.168.88.0
add name=LAN ranges=192.168.88.100-192.168.88.254
add address-pool=LAN interface=vlan-LAN name=dhcp-LAN
# without setting option dns-server DHCP server will serve addresses obtained by DHCP client run on WAN interface
add address=192.168.88.0/24 gateway=192.168.88.1 netmask=24
# IMPORTANT!
# Copy-paste default ip firewall filter rules, as printed out by command
# /system default-configuration print
# (and scroll a bit down)
As the config is intended for the unit without any config (not even factory default), you’ll have to use winbox and connect using MAC connectivity. Use one of ether ports 3, 4 or 5 (those intended for LAN at the end of config exercise). Still you’ll most probably loose connectivity at some point. If you can re-connect, then proceed with config. If you can’t reconnect, try using one of other LAN-to-be ports. If you still can not reconnect, then you’ll have to reset device config and we’ll have to think about some other way of configuring it.
