Need Help SXT-5HPND-HGR2 in PTP Link
Hi There I am setting PTP link between 700m distance through SXT-5HPND-HGR2.
Signal strength is -57~-59dBm , Protocol is NV2.
But I am getting only 25mbps throughput but continuously.
So Provide me any good solution for that or any way to get high through put.
Try reduce the power output to -65 dB
It can be that signal disturb itself.
Your signal is good. It is not too strong. But post more of your config. Or at least ccq and bitrate.
Try with this configuration
http://www.wirelessinfo.be/index.php/mikrotik/pages/omnitikpp
It’s with other device buth configuration is the same
