Need help to chose hardware
Hello what equipment I can use to amplify the gsm 3g or 4g signal and used the connection received in my local network
Tks for ur help
What do you mean: “gain” gsm signal?
Do you need bigger antenna as you have weak signal level or do you want to amplify gsm signal to have better coverage in your area.
If you want second option then it could be a problem as amplifying signal means recreating signal so you are becoming GSM operator as you are building your own “GSM tower” which means that you should have proper licenses to emit GSM signal.
Hi tks for ur quik repli, i know that ther are some mikrotik product that can recive connexion trut simcard slot and can aplifi te qualiti of the signal reception for it to be stable and them we can configure the connection to be use in the local network.
In fact wher i am for the momen we receive the gsm or lte connection but just 2bar so i was wondrin if i can buy lik wAP LTE kit or some one can propose somting else
Tks
