i need to know how to install two mikrotik routers as point-to-point
i have two routers the first router’s ip address are ether1 192.168.0.33 and wlan1 192.168.10.30
and the other router’s ip address are ether1 192.168.1.33 and wlan1 is 192.168.10.33
in the alignment it’s correct 100% and the rx is -43
the polorization is vertical and the distance between them is 700m
i need to configure them to connect both of them please i need your help
Or - if you have assigned the LAN ip addresses from different subnets with a purpose and want to route between two subnets, you just have to configure the necessary static routes on both systems.
And, yes, you should look into getting a bit lower RX level - this is a bit too much…
Thank you all for your help but how to reduce the rx it’s the first time for me to use this router and i’m supposed to install it in this week and the two lans have a different ip they are not the same
i got the rx -77 plz what did u mean by reducing the rx power because it’s negativ so when u say reduce it did u mean towards 0 or u mean towards -100 i need an answer plz
