Need Help to configure web-proxy on 3.10
I have installed v3.10 in my PC, tried to configure transparent web-proxy based in some manuals but it is not working and I don’t know why I have L4.
Bellow is my configuration that I did.
I need help if any can explain me if this rules are OK or not and what need to be done in order to work web-proxy.
what exactly is not working?
requests and hits = 0
probably that
beny30, post your ‘/ip firewall filter’ rules. especially input chain
Yes requests and hits all the time it is 0, and when I monitor them I don’t see anything in the cache. IP Proxy monitor shows that web-proxy is running for a long time, but not answering any client requests. What to do in this case?
I don’t have any rule under /ip firewall filter , here is the picture I don’t know if you asked for this, Do I need to add any rule if yes can you help me please writting here.
Thank you in advance
does your ‘redirect’ rule count packets? or is zero too?
HI all again, at last I found the problem and now web-proxy is working good.
Bellow is the rule that does not worked for me in it was specified “in interface” and “src address” after I removed them from the rule it worked.
Thanks all for your help.
I want to know if web-proxy works in 2.9.51 like in 3.x or not?
yes
