Need help to create a guests network.
In my company we’ve got four HAP ac2 devices that connect between them using CAPsMAN, now I we want to create a guests network. I rode a lot of posts and guides, I’ve seen a lot of videos too but no one do it with CAPsMAN. The only one thing that I found interesting is this post http://forum.mikrotik.com/t/can-someone-tell-me-how-to-make-a-capsman-guest-network-with-new-drivers-ax-and-ac-devices/171363/1 that says that if you create a VLAN on the ether port that is connected your mikrotik device and you attach it as a port in guests bridge should work, but doesn’t for me. Is that well configured or not? And another point is that my DHCP doesn’t work properly, it is not assigning the IPs well and devices don’t appear in ‘leases’. When I connect to my guests Wi-Fi gives me IPs from the local bridge and not even in the range of local Wi-Fi DHCP. I need help.
# apr/16/2024 14:54:48 by RouterOS 6.49.10
# software id = IJH1-AHYL
# model = RBD52G-5HacD2HnD
# serial number = D7160D7D1923
/caps-man channel
add band=2ghz-b/g/n extension-channel=XX name="2.4Ghz(FA)"
add band=5ghz-a/n/ac extension-channel=XXXX name="5Ghz(FA)"
add name=bridge_guest
add admin-mac=08:55:31:77:CF:07 auto-mac=no name=bridge_spa
/interface wireless
# managed by CAPsMAN
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX \
    distance=indoors frequency=auto installation=indoor mode=ap-bridge ssid=\
    MikroTik-77CF0B wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=\
    20/40/80mhz-XXXX distance=indoors frequency=auto installation=indoor \
    mode=ap-bridge ssid=MikroTik-77CF0C wireless-protocol=802.11
/interface vlan
add interface=ether5 name=vlan_guest vlan-id=10
/caps-man datapath
add bridge=bridge_spa client-to-client-forwarding=yes local-forwarding=yes \
    name=SPA_WIFI
add bridge=bridge_guest client-to-client-forwarding=yes local-forwarding=yes \
    name=SPA_GUEST
/caps-man security
add authentication-types=wpa-psk,wpa2-psk disable-pmkid=no encryption=aes-ccm \
    group-encryption=aes-ccm name=SPA_WIFI
add authentication-types=wpa-psk,wpa2-psk encryption=aes-ccm \
    group-encryption=aes-ccm group-key-update=10m name=SPA-GUEST
/caps-man configuration
add channel="2.4Ghz(FA)" channel.skip-dfs-channels=yes country=spain \
    datapath=SPA_WIFI datapath.bridge=bridge_spa hw-retries=4 mode=ap \
    multicast-helper=full name=SPA_WIFI_2.4GHz security=SPA_WIFI ssid=\
    SPA_WIFI
add channel="5Ghz(FA)" channel.skip-dfs-channels=yes country=spain datapath=\
    SPA_WIFI datapath.bridge=bridge_spa guard-interval=any hw-retries=4 mode=\
    ap multicast-helper=full name=SPA_WIFI_5GHz security=SPA_WIFI ssid=\
    SPA_WIFI
    datapath=SPA_GUEST hw-retries=4 mode=ap multicast-helper=full name=\
    SPA_GUEST security=SPA-GUEST ssid=SPA_GUEST
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=pool0 ranges=192.168.101.80-192.168.101.99
add name=dhcp_pool1 ranges=192.168.99.2-192.168.99.15
add address-pool=pool0 disabled=no interface=bridge_spa name=SPA_WIFI
add address-pool=dhcp_pool1 disabled=no interface=bridge_guest name=SPA_GUEST
/caps-man manager
set enabled=yes
/caps-man manager interface
set [ find default=yes ] forbid=yes
add disabled=no interface=bridge_spa
/caps-man provisioning
add action=create-dynamic-enabled hw-supported-modes=b,g,gn \
    master-configuration=SPA_WIFI_2.4GHz name-format=identity \
    slave-configurations=SPA_GUEST
add action=create-dynamic-enabled hw-supported-modes=a,an,ac \
    master-configuration=SPA_WIFI_5GHz name-format=identity
add bridge=bridge_spa interface=ether2
add bridge=bridge_spa interface=ether3
add bridge=bridge_spa interface=ether4
add bridge=bridge_spa interface=ether5
add bridge=bridge_spa interface=wlan1
add bridge=bridge_spa interface=wlan2
add bridge=bridge_guest interface=vlan_guest
add comment=defconf interface=bridge_spa list=LAN
/interface wireless cap
set bridge=bridge_spa discovery-interfaces=bridge_spa enabled=yes interfaces=\
    wlan1,wlan2
add address=192.168.101.195/24 interface=bridge_spa network=192.168.101.0
add address=192.168.99.1/24 interface=bridge_guest network=192.168.99.0
/ip dhcp-client
add address=192.168.99.0/24 dns-server=8.8.8.8,8.8.4.4,1.1.1.1 gateway=\
    192.168.99.1
add address=192.168.101.0/24 dns-server=192.168.101.1 gateway=192.168.101.1
set allow-remote-requests=yes
/ip dns static
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
    "defconf: drop all from WAN not DSTNATed" in-interface-list=WAN \
    src-address=192.168.99.0/24
/system clock
set time-zone-name=Europe/Madrid
/system identity
set name=SPA_WADMIN
/tool mac-server
/tool mac-server mac-winbox
https://help.mikrotik.com/docs/display/ROS/Wireless+Interface#WirelessInterface-VLANtagging
