need help to find schematic diagram
I’am a new member of this forum.
Where can I get electronic schematic diagram of Mikrotik device? or should I buy it?
thank you
Hi
For some of the devices is available under documents, but not for all.
Ex: https://mikrotik.com/product/CCR1036-8G-2SplusEM#fndtn-downloadshttps://i.mt.lv/routerboard/files/CCR1036-8G-2SplusEM-160609132545.png
IMHO he is asking not for functional diagrams but for electrical service diagrams.
Also possible …
hi.
i have a sxtsq lite5
it lightning by high voltages and doesnt have any link data and do not detect in Winbox software.
the transformer module “NS601680” doubtful to be damaged.
i really need to schematic diagram of this product or youre help about repair it.
tnx
Electronic diagram is something more technical. Most probably you will need to contact directly to Mikrotik support to get it (if they provide it) with the specific RouterBOARD model.
Regards.
Did U try NetInstall first?
