Need help with an online game
Ok im a noob when it comes to MikroTik but i have a problem.
I was trying to play a game after upgrading to a MikroTik router.
It worked fine for a bout 15 min then disconnected.
I checked the firewall and i see that the login packets get sent into the defconf: drop invalid. Strange thing is that it was fine for about 15 min. U can also see them in the NAT masquerade.
So i tried just about everything. From disabling the whole firewall, putting all the rules to allow, setting up the UPnP, making port forwards for the games UPD ports, setting up dst-nat rules ..
NOTHING has worked. Also if i plug the cable straight into the modem, everything works fine, also from a phone hotspot.
I am really desperate for some expert advise.
Kind regards .
You will need to provide some more information for people to be able to help you. Can you provide an export of your config so we can see what the router is doing? Try turning off fasttrack as that stops connection tracking and may be part of the issue you are getting.
I have re posted the question to another post, because this one took almost a day to appear here.
Please refer to http://forum.mikrotik.com/t/router-dropping-traffic-as-drop-invalid/124258/1
also a mod can close this, so there wont be 2 same questions.
