Need help with AP configuration
Hi, recently i decided to buy a routerboard + wireless card and use it as an outdoor AP for my network. But i am confused how should i setup the mikrotik og routerboard so that it would work as an AP and not as a router. Can anyone help me with this?
Thank you very much…
First of all you should define what do you want from your AP and conditions you will use it.
I suggest to read wireless documentation to catch, there are also described some examples:
http://www.mikrotik.com/docs/ros/2.9/interface/wireless
