Need Help with complicated scinario
Hello all,
I need your help if it is possible to do this, in a hotel environment, we need to create a wireless login user that can be used on multiple devices simultaneously considering the following.
  • we need to be able to control the speed of this user per 1 device, for example 1 mbps max speed for every device is connected using this user.
  • we need to set the validity time from first use per device mac address not the user login itself, for example if we set the validity one week, so each device is connected using this user can only connect using this user for only one week, after this the mac address for this device should be blocked, and have to remove it manually.
I would appreciate all your responses
Just a suggestion, but i feel it can be done with hotspot.
