Need help with CRS and VLAN configuration
We’re setting up CRS switches in one of the DCs where we peer with multiple other networks, to increase the number of Ethernet and Fibre interfaces available on our CCR1072 routers.
I’m having a problem with vlan’s, trunking and Q-in-Q and hope there’s someone that can assist with our configuration.
Scenario A:
[RouterBoard CCR1072 - ether1/vlan100(c-tag)] ↔ [ether1/vlan100(c-tag) - CRS - ether2/untagged] ↔ [untagged - peering network]
This works fine with the configuration I got from http://wiki.mikrotik.com/wiki/Manual:CRS_examples#Port_Based_VLAN
Scenario B:
[RouterBoard CCR1072 - ether1/vlan100(c-tag)/vlan5(c-tag)] ↔ [ether1/vlan100(c-tag) - CRS - ether2/vlan5(c-tag)] ↔ [vlan5(c-tag) - peering network]
This does not work using the same Port Based VLAN config from the Wiki because the vlan5(c-tag) get ignored by the CRS as the ports on the CRS have not been configured to be a member of VLAN ID 5.
I do not want to specify the VLAN ID that will be transported through the CRS as any traffic coming from the peering provider should simply get an additional c-tag when passing through the CRS to our CCR1072 and visa versa. Any peering network should be able to pass any VLAN ID through the CRS they want to, without the CRS switching the traffic between similar VLAN IDs, if used by more than one provider.
Should I rather be looking at Q-in-Q VLAN tunnelling and s-tags as described in http://wiki.mikrotik.com/wiki/Manual:CRS_examples#VLAN_Tunneling_.28Q-in-Q.29 or am I missing something small?
actually we want to use vlan for our pop. every pop should be in different vlan and each pop is connected over fiber using l3 switches (sfp compatible). as per the image we want that each l3 i.e. the first switch at pop should be connected with mikrotik then the distribution should be done as per the vlan and clients should get ip from mikrotik dhcp created individually for each vlan. we tried from our side but the thing is directly connected l3 switch is communicating with mikrotik but other l3 switches are not connecting with mikrotik due to which client doesn’t get ip from mikrotik
we got ping from mikrotik to other l3 switches at pop but other pop not getting internet and trunk and access port of the switch doesn’t communicate.
our hardware list is
  1. mikrotik routeros 6.31(pc version)
  2. cisco 2950 l3
    3.cisco 3750 l3
    4.cisco sf300 l3
    every switch is having fiber as well as ethernet port
thanks in advance
