Need Help With Firewall
Issues:
  1. Firewall is blocking getting online
  2. Hairpin nat not working
  3. Firewall is probably not correct
Would like the firewall to:
  • block everything that is not allowed
  • use the brute force stuff
  • separate vlans from router
  • forward port 8090, 6767 & 6868 to 192.168.1.26
  • allow for pptp vpn
  • get hairpin nat working
I have tried to do this but I think some of my logic is off and some of my placement of code is off. If anyone has any input or can point me in the right direction I would really appreciate it. Thank you.
add comment=“Local Bridge” l2mtu=1598 name=bridge-local
add comment=“Vlan1 Bridge” l2mtu=1594 name=bridge-vlan1
add comment=“Vlan2 Bridge” l2mtu=1594 name=bridge-vlan2
set 0 name=ether1-gateway
set 1 name=ether2-local
set 2 name=ether3-vlan1
set 3 name=ether4-vlan2
set 4 name=ether5-trunk
/interface vlan
add interface=bridge-local l2mtu=1594 name=vlan-vlan1-ether5 vlan-id=101
add interface=bridge-local l2mtu=1594 name=vlan-vlan2-ether5 vlan-id=102
add name=pool-local ranges=192.168.1.100-192.168.1.254
add name=pool-vlan1 ranges=192.168.2.2-192.168.2.254
add name=pool-vlan2 ranges=192.168.3.2-192.168.3.254
add name=pool-vpn ranges=192.168.10.1-192.168.10.10
add address-pool=pool-local disabled=no interface=bridge-local name=local
add address-pool=pool-vlan1 disabled=no interface=bridge-vlan1 name=vlan1
add address-pool=pool-vlan2 disabled=no interface=bridge-vlan2 name=vlan2
/ppp profile
set 1 local-address=192.168.1.1 remote-address=pool-vpn
add bridge=bridge-local interface=ether2-local
add bridge=bridge-local interface=ether5-trunk
add bridge=bridge-vlan1 interface=ether3-vlan1
add bridge=bridge-vlan1 interface=vlan-vlan1-ether5
add bridge=bridge-vlan2 interface=ether4-vlan2
add bridge=bridge-vlan2 interface=vlan-vlan2-ether5
/interface pptp-server server
set enabled=yes
add address=192.168.1.1/24 interface=bridge-local
add address=192.168.2.1/24 interface=bridge-vlan1
add address=192.168.3.1/24 interface=bridge-vlan2
/ip dhcp-client
add comment=“default configuration” disabled=no interface=ether1-gateway
add address=192.168.1.0/24 dns-server=192.168.1.1 gateway=192.168.1.1
add address=192.168.2.0/24 dns-server=192.168.2.1 gateway=192.168.2.1
add address=192.168.3.0/24 dns-server=192.168.3.1 gateway=192.168.3.1
set allow-remote-requests=yes
add chain=input comment=“default configuration” protocol=icmp
add chain=input comment=“default configuration” connection-state=established
add chain=input comment=“default configuration” connection-state=related
add chain=input comment=vpn dst-port=1723 protocol=tcp
add chain=input comment=vpn protocol=gre
add action=drop chain=input comment=“default configuration” connection-state=
invalid disabled=yes in-interface=ether1-gateway
add action=jump chain=input disabled=yes in-interface=bridge-vlan1
jump-target=input-vlan2
add action=jump chain=input disabled=yes in-interface=bridge-vlan2
add chain=input disabled=yes in-interface=bridge-local
add action=drop chain=input disabled=yes
add chain=forward disabled=yes out-interface=ether1-gateway
add action=drop chain=forward disabled=yes
add chain=input-vlan2 disabled=yes dst-port=53 protocol=tcp
add chain=input-vlan2 disabled=yes dst-port=53 protocol=udp
add chain=input-vlan2 disabled=yes dst-port=67 protocol=udp
add chain=input-vlan2 disabled=yes dst-port=68 protocol=udp
add action=drop chain=input comment=“drop ssh brute forcers” disabled=yes
dst-port=22 protocol=tcp src-address-list=ssh_blacklist
add action=add-src-to-address-list address-list=ssh_blacklist
address-list-timeout=1w3d chain=input connection-state=new disabled=yes
dst-port=22 protocol=tcp src-address-list=ssh_stage3
add action=add-src-to-address-list address-list=ssh_stage3
address-list-timeout=1m chain=input connection-state=new disabled=yes
dst-port=22 protocol=tcp src-address-list=ssh_stage2
add action=add-src-to-address-list address-list=ssh_stage2
dst-port=22 protocol=tcp src-address-list=ssh_stage1
add action=add-src-to-address-list address-list=ssh_stage1
add action=dst-nat chain=dstnat dst-port=53 protocol=tcp src-address=
192.168.3.0/24 to-addresses=208.67.222.222
add action=dst-nat chain=dstnat dst-port=53 protocol=udp src-address=
add action=dst-nat chain=dstnat comment=“CCTV Port Forward” dst-port=8090
in-interface=ether1-gateway protocol=tcp src-port=“” to-addresses=
192.168.1.26 to-ports=8090
add action=dst-nat chain=dstnat dst-port=6767 in-interface=ether1-gateway
protocol=tcp to-addresses=192.168.1.26 to-ports=6767
add action=dst-nat chain=dstnat dst-port=6868 in-interface=ether1-gateway
protocol=tcp to-addresses=192.168.1.26 to-ports=6868
protocol=udp to-addresses=192.168.1.26 to-ports=6767
protocol=udp to-addresses=192.168.1.26 to-ports=6868
add action=masquerade chain=srcnat comment=“Hairpin Nat” dst-address=
192.168.1.26 dst-port=8090 out-interface=ether2-local protocol=tcp
src-address=192.168.1.0/24
add action=dst-nat chain=dstnat comment=“Hairpin Nat” dst-address-type=local
dst-port=8090 protocol=tcp to-addresses=192.168.1.26
add action=masquerade chain=srcnat comment=“default configuration”
out-interface=ether1-gateway to-addresses=0.0.0.0
/ip neighbor discovery
set ether1-gateway disabled=yes
set ether3-vlan1 disabled=yes
set ether4-vlan2 disabled=yes
set bridge-vlan1 disabled=yes
set bridge-vlan2 disabled=yes
set vlan-vlan1-ether5 disabled=yes
set vlan-vlan2-ether5 disabled=yes
Which version are you running ?
check:
What’s new in 6.7rc1 (2013-Nov-19 11:17):
*) ipsec - fix policy bypass on IPv6 gre, ipip, eoip tunnels;
*) userman - fix crash on tilera;
*) fixed hairpin nat on bridge with use-ip-firewall=yes;
*) fixed vlan on bridge after reboot having 00:00:00:00:00:00 mac address;
*) address-list - allow manually adding timeoutable entries;
*) address-list - show dynamic entry timeout;
What’s new in 6.6 (2013-Nov-07 13:04):
*) winbox - fixed problem where all previous session opened windows were read only;
*) certificate - no more ‘reset-certificate-cache’ and ‘decrypt’ commands,
private keys can be decrypted only on ‘import’, use ‘decrypt’ before upgrade if needed;
*) fixed arp-reply only with more than one ip address on interface;
*) fixed RB400 not to reboot by watchdog during micro-sd format;
*) web proxy - fix SPDY server push handling;
*) certificate - merged ‘/certificate ca issued’, ‘/certificate scep client’ and
‘/certificate templates’ into ‘/certificate’;
*) console - :foreach command can iterate over keys and values in an array,
by specifying two counter variables, e.g.:
:foreach k,v in=[/system clock get] do={:put “$k is $v”};
*) added support for new Intel 10Gb ethernet cards (82599);
*) certificates - fixed certificate import;
*) wireless - fixed crash when dfs was enabled on pre-n wireless cards;
*) fixed port flapping on CCR;
What’s new in 6.5 (2013-Oct-16 15:32):
*) tftp - added data packet pipelining for read requests;
*) console - exported physical interface configuration uses ‘default-name’
instead of item number to match relevant interface;
*) console - report all constituent errors for parameters with multiple
alternative value types;
*) certificates - merge ‘/certificate ca’ into ‘/certificate’, use set-ca-passphrase to maintain CA functionality;
*) lcd - backlight option is replaced with “/lcd backlight” command
*) dhcp server - added option to disable conflict-detection;
*) console - ‘:return’ does not trigger ‘on-error=’ action of ‘:do’ command;
*) route - fixed crash that could be triggered by change in nexthop
address resolution;
*) route - some imported VPNv4 routes were not using MPLS labels;
*) route - imported VPNv4 routes were not always updated or removed when
the original route changed;
*) winbox - fixed problem where all settings were read only on first open;
*) ovpn server - use only ciphers that are allowed not that client requested;
*) ssh client - fixed public key authentication;
*) ipsec - fix peer mathing with non byte aligned masks;
*) fix routerboot upgrading if RouterOS is partitioned;
*) add support for second serial port on CCR boards;
*) fix serial port baudrate selection on CCR boards;
*) ethernet interface stats that are behind switch chip
show real hw stats instead of just the traffic that goes through cpu;
What’s new in 6.4 (2013-Sep-12 13:52):
*) wireless - improved 802.11n wireless retransmission (doesn’t effect nstreme/nv2)
*) ovpn - allow to specify server via dns name;
*) winbox - fixed problem where ipv6 routes with non local link address gateway
could not be added;
*) fixed watchdog on mipsle boards;
*) traceroute - added count & max-hops parameters;
*) traceroute - added back use-dns parameter;
*) fixed usb Yota LTE modem hangup;
*) console - make newly added item names always immediately available;
*) graphing - make sure that interface graphs gets preserved across reboots;
What’s new in 6.3 (2013-Sep-03 12:25):
*) ssh - fixed denial of service;
*) traceroute - show mpls labels as well;
*) bug fix - sometimes some new interfaces could not be created properly any more (f.e. some pppoe clients could not connect);
*) console - added ‘/console clear-history’ command that clears command-line
history for all users, requires ‘policy’ policy;
*) sstp - limit packet queue for each device;
*) RB2011L - fixed occasional gigabit switch-chip lockup;
*) user manager - will warn on 1MB and stop before reaching minimum of 500KB disk space;
*) hotspot - do not account traffic to local hotspot pages;
*) ppp, hotspot - added ability to specify where to insert rate limiting queue,
it’s parent and type;
*) pptp, l2tp, sstp - allow to specify server via dns name;
*) dhcp - added ability to specify where to insert rate limiting queue;
*) www proxy - support ipv6 parent proxy;
*) webfig - fixed problem when opening quickset page country
was automaticly changed to etsi;
*) traceroute - added mtr like pinging;
*) fix queues - correct queue was not installed when last child removed;
*) fix simple queues - sometimes some simple queues would stop
working after configuration changes;
*) console - fixed issue with local variables having non-empty value
before first assignment;
*) console - fixed command “:global name” without second argument to not
create or change global variable “name”, only effect is to make “name”
refer to global variable.
*) console - fixed passing local variables as argument to function;
*) RB1200 - fixed crash when receiving over l2mtu size packets
on some ethernet interfaces;
What’s new in 6.2 (2013-Aug-02 10:37):
*) console - added “on-error” argument to ‘:do’ command that is executed
if command raises error;
*) hotspot - fixed chap error after failed http-chap login (broken in v6.1);
*) console - added new ‘:return’ command that interrupts execution of script
and passes argument as return value if script was called as function;
*) routerboot - fixed upgrade from RouterOS (could fail on some units);
*) userman - fixed payment gateway response notify processing;
*) console - resolved issue with ‘from-pool’ propery in ‘/ipv6 address’;
*) console - array value syntax in expressions ‘{1;2;3;4}’ now can
specify values with word keys as ‘{a=1;b=2}’;
*) console - added ‘verbose’ argument to ‘/import’ command that enables
line-by-line script import. By default import whole script at once
and don’t print it, as it was in version 6.0;
*) console - ‘:global’, ‘:local’ and ‘:set’ commands have new parameter ‘do’
that allows assigning block of commands to the variable;
*) console - global variables now are common to all users and are
available to all users with at least “read,write,test,policy” policy;
*) console - fixed parameter passing to scripts. Script parameters can
be accessed without declaring them with ‘:local’ and ‘:global’ commands.
For backwards compatibility global variables are first looked up in
script parametrs;
*) console - ‘$var 1 2 a=“a” b=“b”’ syntax for passing parameters to commands
stored in a variable. Parameters are accessed as ‘$1’ ‘$2’ ‘$a’ ‘$b’;
*) ipsec - fixed peer address matching;
*) ups - query smart ups capabilities before issuing any commands;
*) improved CCR responsiveness on other interfaces when one interface is under attack;
*) sms tool - added sim-pin setting;
*) dhcp server - framed routes are now also added to the server routing table;
*) dhcpv6 server - added binding-script option;
*) proxy - allow multiple src-address for ipv4 and ipv6;
*) eoip,gre tunnels could occasionally crash multicore router;
*) fixed bug - sometimes some types of interfaces would stop working;
*) ipsec sometimes could crash kernel on CCR;
*) connection tracking sometimes could crash kernel on CCR;
*) ppp,pptp,l2tp,sstp - added default-route-distance parameter;
*) scep - “/cert scep ra” merged into “/cert scep client” without saving ra config;
*) ipsec - fix phase1 autonegotiation on little endian platforms;
*) pppoe server - allow service with empty service-name to accept all pppoe clients;
*) lcd - current-screen option is replaced with “/lcd show” command
*) lcd - current-interface option is replaced with “/lcd interface display” command
*) graphing - make graphs stable on ppp & ovpn interfaces;
*) www, hotspot - fixed problem when www service stopped responding on high load;
*) winbox, webfig: allow to enter space in the text fields;
*) webfig - fixed configuration of VPLS & routing filters;
*) lcd - added option for enabling or disabling the touch screen;
*) lcd - added options for screen switching;
*) lcd - up to 10 non-physical interfaces can now be added to the lcd;
*) lcd - all interface graph screen can now be customized from /lcd interface page;
*) backup - changed default backup file name to -
-.backup
for file browsers to sort them properly;
*) webfig - it did not work in Opera;
*) webfig - made terminal work again;
*) winbox - added ability to fully set up traffic generator in winbox;
*) trafficgen - allow ranges for ip addrs and udp ports;
*) trafficgen - add tcp header support;
*) queue simple - fixed bug - actual queue order sometimes was wrong;
*) queue simple - queue is not invalid when at least one of target interfaces is up;
*) fixed crash when setting master-port on AR8327 switch chips;
*) fixed addresslist - dynamic entries sometimes would still
show up even afther being timed out;
*) added /ip settings allow-hw-fast-path setting to control AR8327N hardware ipv4 fast path;
*) vrrp - allow more than one vrrp on interface;
What’s new in 6.1 (2013-Jun-12 11:50):
*) pptp, l2tp - fixed crash when tunnel mru was too big and fragmented ip packet
was received;
*) hotspot - fixed problem when after upgrade hotspot html directory was empty;
*) ipv6 nd - dns dynamic-servers were not included in router advertisements;
*) winbox - fixed problem Switch menu disappeared on RB2011;
*) fixed memory amount issue on RB1100AHx2;
*) console - ‘/import’ prints each command that is executed;
*) console - ‘import’ has new argument ‘from-line’ that starts executing
commands after specified line;
*) secure api - fixed problem when wrong client ip address was reported;
*) hotspot - fixed universal client;
*) api - added support for API over TLS (SSL);
*) api - api service is now enabled by default;
*) ppp - do not show R flag for locally authenticated users;
*) vrrp - fixed ah authentication;
*) webfig - added support for RADIUS authentication (via MS-CHAPv2);
*) ipsec - for peers with full IP address specified system will
autostart ISAKMP SA negotiation;
*) trafficgen - added inject-pcap command for replaying pcap files into network;
*) dns - retry queries with tcp if truncated results received;
*) improved queue statistics updating;
*) fix 1G linking with some Cisco devices (affects RB7xx, RB9xx, RB1100, RB2011, CCR);
What’s new in 6.0 (2013-May-17 14:04):
*) ipsec - added /peer passive option which will prevent starting ISAKMP negotiation
and signifies xauth responder/initiator side;
*) RouterBOARD - default wireless config now includes password - serial number;
*) lte - support YOTA WLTUBA-107;
*) console - fixed crash when variable name was not specified for
‘:global’, ‘:local’, ‘:set’, ‘:for’ and ‘:foreach’ commands;
*) hotspot - added mac-cookie login method;
http://wiki.mikrotik.com/wiki/Manual:Hotspot_Introduction#MAC_Cookie
*) lcd - show a message when system shutdown is complete;
*) lcd - added Log screen which is accessible through the Main Menu
and shows log messages where action=echo;
*) ipsec - added pre-shared-key-xauth and rsa-signature-hybrid
authentication methods;
*) increased max l2mtu on CCR to 10226 bytes;
*) fixed crash on RB1200;
*) fixed bonding - did not work after remove, undo;
*) fixed queues - router could become unresponsive when configuring queues;
I am on version 5.26.
What version is most stable right now?
Do I have to upgrade to 6.7 in order for this to work?
Thanks.
What hardware are you on?
Why is this disabled?
Also this looks odd…
Eric the whole firewall looks odd! It was disabled because it was not working enabled, and then I just disabled the whole thing.
Your other thing that you said looks odd… isn’t that the default masquerade rule?
Maybe we can take this one thing at a time and I can learn something and it might help someone else out.
I’ll look through the whole thing in a bit from my laptop. Can you post the export of just the firewall inside of the code tags…
Sent from my SCH-I545 using Tapatalk
Also what was it doing wrong? I’m pretty sure I remember what you want, but could you post the basic parameters you need? Eg what you want it to do?
I could not get the hairpin nat to work, and something in the firewall was preventing me from getting internet access, so I had to totally disable it.
Here is what I am trying to accomplish, and have working so far, except for the firewall:
  • wan on port 1
  • lan on port 2
  • vlan1 on port 3 (guest)
  • vlan2 of port 4 (kids)
  • trunk of lan, vlan1 & vlan2 on port 5
  • camera system on port 8090 with address 192.168.1.26
  • hairpin nat for camera system (this is NOT working)
I would like the firewall to:
  • provide good overall protection, with default drop rule, etc
  • provide protection against floods (like I have now, unless you know a better way, but I think it’s in the wrong place)
  • separate the lan, vlan1, & vlan2 so they are secure from one another
  • force vlan2 to only use opendns dns servers 208.67.222.222 (like we talked about)
  • allow hairpin nat
Here is the current firewall:
out-interface=ether1-gateway to-addresses=0.0.0.0Thanks Eric.
Alright... here it is... There were some random errors in it. Try this out and well see how it works. You may want to add it a piece at a time.
INPUT CHAIN
add chain=input comment="Connection State - Established" connection-state=established
add chain=input comment="Connection State - Related" connection-state=related
add action=drop chain=input comment="Connection State - Invalid" connection-state=invalid
add action=jump chain=input comment="ICMP - From Internet - Jump" in-interface=ether1-gateway jump-target=ICMP protocol=icmp
add chain=input comment="ICMP - From Local" protocol=icmp in-interface=!ether1-gateway
add action=drop chain=input comment="TCP - Syn Flood Suppression - Drop SynFlood" src-address-list=SynFlood
add action=add-src-to-address-list address-list=SynFlood address-list-timeout=30m chain=input comment="TCP - Syn Flood Detection - Add To SynFlood (30 Connections Per IP Address)" connection-limit=30,32 protocol=tcp tcp-flags=syn
add action=drop chain=input comment="TCP - Port Scan Detection - Drop Port Scans (21,3s,3,1)" protocol=tcp psd=21,3s,3,1 add action=tarpit chain=input comment="TCP - DoS Attack Supression - Tarpit BlackList (3 Connections Per IP Address)" connection-limit=3,32 protocol=tcp src-address-list=BlackList
add action=add-src-to-address-list address-list=BlackList address-list-timeout=1d chain=input comment="TCP - DoS Attack Detection - Add to BlackList for 1d (10 Connections per IP Address)" connection-limit=10,32 protocol=tcp
add chain=input comment="SSH Brute Force" in-interface=ether1-gateway dst-port=22 protocol=tcp action=jump jump-target=sshBruteforce
add chain=input comment="Allow Local" in-interface=bridge-local
add action=jump chain=input comment="VLAN1 Traffic Jump" in-interface=bridge-vlan1 jump-target=vlan1
add action=jump chain=input comment="VLAN2 Traffic Jump" in-interface=bridge-vlan2 jump-target=vlan2
add action=jump chain=input comment="VPN Traffic" in-interface=ether1-gateway jump-target=vpn
add action=drop chain=input comment="Default Drop"
FORWARD
add chain=forward comment="Connection State - Established" connection-state=established
add chain=forward comment="Connection State - Related" connection-state=related
add action=drop chain=forward comment="Connection State - Invalid" connection-state=invalid
add chain=forward comment="Forward to Ether1-Gateway" out-interface=ether1-gateway
add chain=forward comment="DST NAT - Port 8090" dst-port=8090 dst-address=192.168.1.26
add chain=forward comment="DST NAT - Port 6767" dst-port=6767 dst-address=192.168.1.26
add chain=forward comment="DST NAT - Port 6868" dst-port=6868 dst-address=192.168.1.26
add action=drop comment="Default Drop" chain=forward
OUTPUT
VLAN1
add chain=vlan1 comment="VLAN1 DNS TCP" dst-port=53 protocol=tcp
add chain=vlan1 comment="VLAN1 DNS UDP" dst-port=53 protocol=udp
add chain=vlan1 comment="DHCP Port 67" dst-port=67 protocol=udp
add chain=vlan1 comment="DHCP Port 68" dst-port=68 protocol=udp
VLAN2
add chain=vlan2 comment="DHCP Port 67" dst-port=67 protocol=udp
add chain=vlan2 comment="DHCP Port 68" dst-port=68 protocol=udp
VPN
add chain=vpn comment="VPN Traffic" dst-port=1723 protocol=tcp
add chain=vpn comment="VPN Traffic" protocol=gre
ICMP
add chain=ICMP comment="ICMP - Allow Echo Reply (0:0-255), Limit 5pps" icmp-options=0 limit=5,5 protocol=icmp
add chain=ICMP comment="ICMP - Allow Destination Unreachable (3:0-255), Limit 5pps" icmp-options=3 limit=5,5 protocol=icmp
add chain=ICMP comment="ICMP - Allow Source Quench (4:0), Limit 5pps" icmp-options=4 limit=5,5 protocol=icmp
add chain=ICMP comment="ICMP - Allow Echo Request (8:0), Limit 5pps" icmp-options=8 limit=5,5 protocol=icmp
add chain=ICMP comment="ICMP - Allow Time Exceeded (11:0), Limit 5pps" icmp-options=11 limit=5,5 protocol=icmp
add chain=ICMP comment="ICMP - Allow Parameter Bar (12:0), Limit 5pps" icmp-options=12 limit=5,5 protocol=icmp add action=drop chain=ICMP comment="ICMP - Drop All Others" protocol=icmp
SSH
add action=drop chain=sshBruteforce src-address-list=ssh_blacklist
add action=add-src-to-address-list address-list=ssh_blacklist address-list-timeout=1w3d chain=sshBruteforce src-address-list=ssh_stage3
add action=add-src-to-address-list address-list=ssh_stage3 address-list-timeout=1m chain=sshBruteforce src-address-list=ssh_stage2
add action=add-src-to-address-list address-list=ssh_stage2 address-list-timeout=1m chain=sshBruteforce src-address-list=ssh_stage1
add action=add-src-to-address-list address-list=ssh_stage1 address-list-timeout=1m chain=sshBruteforce protocol=tcp
DST-NAT
add action=dst-nat comment="DNS TCP for VLAN2" chain=dstnat dst-port=53 protocol=tcp in-interface=bridge-vlan2 to-addresses=208.67.222.222
add action=dst-nat comment="DNS UDP for VLAN2" chain=dstnat dst-port=53 protocol=udp in-interface=bridge-vlan2 to-addresses=208.67.222.222
add action=dst-nat chain=dstnat comment="Port 8090 Forward" dst-port=8090 dst-address-type=local protocol=tcp to-addresses=192.168.1.26
add action=dst-nat chain=dstnat comment="Port 6767 Forward" dst-port=6767 dst-address-type=local protocol=tcp to-addresses=192.168.1.26
add action=dst-nat chain=dstnat comment="Port 6868 Forward" dst-port=6868 dst-address-type=local protocol=tcp to-addresses=192.168.1.26
SRC-NAT
add chain=srcnat comment="Hairpin Port 8090" src-address=192.168.1.0/24 dst-address=192.168.1.26 protocol=tcp dst-port=8090 out-interface=bridge-local action=masquerade
add chain=srcnat comment="Hairpin Port 6767" src-address=192.168.1.0/24 dst-address=192.168.1.26 protocol=tcp dst-port=6767 out-interface=bridge-local action=masquerade
add chain=srcnat comment="Hairpin Port 6868" src-address=192.168.1.0/24 dst-address=192.168.1.26 protocol=tcp dst-port=6868 out-interface=bridge-local action=masquerade
add action=masquerade chain=srcnat comment="Masquerade" out-interface=ether1-gateway
Eric, thank you. I am going to go over this in detail and respond to each thing you did. I want to see if I understand it to the point of doing it myself. It looks great. You took the time to label things and make them readable.
I will give it a try tomorrow and let you know, and also write back with my comments and maybe you can let me know if I got it right.
Sounds good…
I forgot about the routeros version… which is the MOST stable? Right now I am still on 5.26. I am looking for rock solid with no bugs, so if I need to stay on 5.26 I will.
Eric,
I went through your firewall. I fixed a few typos that were causing install errors and I’ll post the final working firewall with the changes tomorrow.
The only error I am having a problem with now is:
[admin@MikroTik] /ip firewall filter> add chain=forward comment=“DST NAT - Port 8090” dst-port=8090 dst-address=192.168.1.26
failure: ports can be specified if proto is tcp or udp
[admin@MikroTik] /ip firewall filter> add chain=forward comment=“DST NAT - Port 6767” dst-port=6767 dst-address=192.168.1.26
[admin@MikroTik] /ip firewall filter> add chain=forward comment=“DST NAT - Port 6868” dst-port=6868 dst-address=192.168.1.26
Do you know what this means?
Yeah… add protocol=tcp… totally forgot it.
I added the protocol and it loaded successfully.
It seems that the port forwarding is NOT working. When I do a port check to see if port 8181 is open, it is closed. What do you think is the issue?
8181? What port is that?.. I didn’t have a forward for that one…
I’m losing my mind! I mean 8090
Post your most recent export. So it isn’t working? Just that part?
