since a few weeks i can watch irregular incoming bursts, but i don’t know how i can handle it in a better way. Maybe someone could help me with that problem?
Here are my filters what i’ve done till now:
0 ;;; Allow Input AccessList
chain=input action=accept src-address-list=AccessList
1 ;;; Allow AccessList to RFC1918
chain=forward action=accept src-address-list=AccessList dst-address-list=rfc1918
2 ;;; Drop ext. DNS Query
chain=input action=drop protocol=udp in-interface=Backbone-Port1 dst-port=53
3 ;;; Log all prot. Bursts
chain=input action=log connection-limit=3,32 log-prefix="BURST BLOCK"
4 ;;; Slow Down Blacklist
chain=input action=tarpit protocol=tcp src-address-list=blocked-addr connection-limit=3,32
5 ;;; Drop all prot. Blacklist
chain=input action=drop src-address-list=blocked-addr connection-limit=3,32
6 ;;; Blacklist Bursts
chain=input action=add-src-to-address-list address-list=blocked-addr address-list-timeout=1d connection-limit=3,32
7 ;;; SYN Flood protect
chain=input action=jump jump-target=SYN-Protect tcp-flags=syn connection-state=new protocol=tcp
8 chain=SYN-Protect action=accept tcp-flags=syn connection-state=new protocol=tcp limit=10,5
9 chain=SYN-Protect action=drop tcp-flags=syn connection-state=new protocol=tcp
10 X ;;; Log RFC1918
chain=forward action=log src-address-list=!rfc1918 dst-address-list=rfc1918 log-prefix="DROP RFC1918"
11 ;;; Drop RFC1918
chain=forward action=drop src-address-list=!rfc1918 dst-address-list=rfc1918
These bursts are any kind of attacks. If i would know which kind of packets are sent, i could stop that :-/ Don’t know how to track this. It looks like a DDoS yes … Any ideas how i can stop that or to find out which protocolls these are?
Thanks for the advise, but you will understand i can’t sit 24 hours in front of the torch tool. We also have more than 60k connections / second from our customers, so torch tool hangs up many times.
ok i have to admit that the load on that link and torch might be a problem … this is something you might want to test before in a lab. you can use the bandwidth monitor tool to send out an email once you facing a burst and jump in to investigate. if the router/torch is not powerful enough i suggest a powerful server + linux + bridge of 2 gbit interfaces + all the nice tools to investigate you have on linux … you can put it transparent in front of your routers backbone-port.
i did that in the past: in a datacenter we had 1 server just for such purpose and it’s even possible to put it transparent in between without re-cabling ( just by changing vlan config on the switch )
you could add some filterrules for different ports/protocols just with accept action and then monitor the hit-counters. it’s difficult to say which rule exactly are the best one as we not know what we are looking for. it might be enough to see in which direction you need to investigate further, but tools like iftop or torch give you more realtime information and you can jump between different “views”: who’s top talker? which protocol make the most traffic? …
