Need help with IPSec script with dynamic IP changing
Here is my current script that is failing (Sorry, I am new at scripting and coding):
:local WANip [/ip address get [find interface=“ether1-gateway”] address]
:log info “Interface IP is $WANip”
:local WANip [:pick “$WANip” 0 ([:len $WANip] - 3)]
:log info “IP sans the slash notation is $WANip”
/ip ipsec policy set 0 src-address= $WANip sa-src-address=$WANip
I need the src-address=$WANip to have /32 and the sa-src-address=$WANip to not have a /32. The sa-src-address is working but the src-address is not.
Please help. Thanks.
  1. Right now you’re using the same WANip variable for what should be 2 different variables.
  2. On the last line, it’s a better idea to use [find] instead of a number (set 0) because the number doesn’t exist unless you do a print command prior to, and even then the number may change if items are added or removed. Using [find], you want to search for something in that item that won’t change. For the example, by adding a unique comment to the policy, you can use the [find] command as I did below.
    :local WANip1 [/ip address get [find interface=“ether1-gateway”] address]
    :log info “Interface IP is $WANip1”
    :local WANip2 [:pick “$WANip1” 0 ([:len $WANip1] - 3)]
    :log info “IP sans the slash notation is $WANip2”
    /ip ipsec policy set [find comment=“myIPsec”] src-address=$WANip1 sa-src-address=$WANip2
Thanks for the help. The issue is that the interface has a netmask of /24 ex. 1.1.1.1/24. I need it to capture 1.1.1.1 but add /32 ex. 1.1.1.1/32.
So, I need a way of taking $WANip2 (the one without the netmask) and appending /32 to the end of it.
Thanks.
Ah, ok. Change this line to:
:local WANip2 ([:pick “$WANip1” 0 ([:len $WANip1] - 3)].“/32”)
Thanks. It works. I appreciate the help.
I have a script to compare whether WAN IP address has been changed and another script to update sa-src-address. Do I need to add something else to the script like kill remote peers and flush installed SAs?
Here is the script I wrote... It does EoIP over IPSec. Basically it looks for IPSec Peers with a comment that looks like
"+eoip+" ... it then looks for the policy, eoip tunnel, etc that all share the same comment. You can use this to update as many as you want...
Dynamic Site To Site VPN Script - EoIP over IPSec
Set Comments (Tunnel, Peer, Policy) = "+eoip+"
Variables
:local currentLocalSiteInterface "ether01-gateway"
:local currentLocalSite ""
:local forceUpdate false
:local IPSecCyclePeers false
:local IPSecFlushSAs false
:local IPSecKillConnections false
Script
:global localSite
#:set currentLocalSite [/ip address get [/ip address find interface=$currentLocalSiteInterface] address]
:set currentLocalSite [/ip dhcp-client get [/ip dhcp-client find interface=$currentLocalSiteInterface] address]
:set currentLocalSite [:pick $currentLocalSite 0 [:find $currentLocalSite "/" -1]]
:if ([:typeof $localSite] = "nothing") do={
:set localSite ""
:if ($currentLocalSite != $localSite) do={
:set forceUpdate true
:set localSite $currentLocalSite
/ip ipsec {
:local hadUpdate false
:foreach i in=[peer find comment~"^([^+]*\\+eoip\\+([^+]*)\$"] do={
	:local remoteSite [peer get $i address]
	:set remoteSite [:pick $remoteSite 0 [:find $remoteSite "/" -1]]
	:local peerComment [peer get $i comment]
	:local policyNumber [policy find comment=$peerComment]
	:local peerNumber $i
	:local tcomment [:pick $peerComment ([:find $peerComment "+"]+1) [:len $peerComment]]
	:local mode [:pick $tcomment 0 ([:find $tcomment "+"])]
	:local dnsName [:pick $tcomment ([:find $tcomment "+"]+1) [:len $tcomment]]
	:do {
		:local currentRemoteSite [:resolve $dnsName]
		:if ($forceUpdate || $remoteSite != $currentRemoteSite) do={
			peer set $peerNumber address="$currentRemoteSite/32"
			policy set $policyNumber dst-address="$currentRemoteSite/32" src-address="$currentLocalSite/32" sa-dst-address=$currentRemoteSite sa-src-address=$currentLocalSite
			:local tunnelNumber [/interface eoip find comment=$peerComment]
			/interface eoip set $tunnelNumber remote-address=$currentRemoteSite
			:if ($IPSecCyclePeers) do={
				peer disable $peerNumber
				peer enable $peerNumber
			:set hadUpdate true
	} on-error={
		:log error ("DynamicSiteToSiteVPNMini: Failed Updating - \"" . $peerComment . "\"")
:if ($hadUpdate) do={
	:if ($IPSecFlushSAs) do={
		installed-sa flush
	:if ($IPSecKillConnections) do={
		remote-peers kill-connections
Thanks for the script, I will certainly use it some day. At the moment I will only use part of the script.
No worries. I actually have a ton of scripts for different things I wrote over time. I’d love to put them on the WIKI, but its not open for editing any more.
Feel free to do whatever you want with it… I have versions for EOIP, IPIP, Straight IPSec, etc… … I also have a massive script with ALL of them built in… it just looks at the comments.. e.g. +ipip+hostname, +eoip+hostname, etc.
