Need help with IPSec setup....
I’m looking at replacing a Cisco router with a MikroTik, problem at the moment is the VPN tunnel that clients need. I’ve set up how I ‘think’ it should work on the MikroTik but its just not working… It looks like the IPSec tunnel is up, but I can’t ping anything on the other side. I’m not an expert in IPSec so i’m not entirely sure how to diagnose the issue or see whats wrong
Here is the information I have been given
VPN IP Address: xxx.12.184.237
Shared Secret: HIDDEN
Private IP Address: 172.29.43.237
Server IP Address: 172.27.1.91
Here is how i’ve configured the MikroTik in a way that I ‘think’ should work (but doesn’t):
 add name=IPSEC_VPN protocol-mode=none
 add address=172.29.43.237 interface=IPSEC_VPN network=172.29.43.237
/ip ipsec proposal
 set [ find default=yes ] enc-algorithms=aes-128-cbc
 add auth-algorithms=md5 enc-algorithms=3des name=proposal1
 add action=masquerade chain=srcnat out-interface=ether7
 add action=masquerade chain=srcnat out-interface=IPSEC_VPN
/ip ipsec peer
 add address=xxx.12.184.237/32 enc-algorithm=3des hash-algorithm=md5 local-address=172.29.43.237 nat-traversal=no secret=*HIDDEN*
/ip ipsec policy
 add dst-address=172.27.1.0/24 proposal=proposal1 sa-dst-address=xxx.12.184.237 sa-src-address=172.29.43.237 src-address=0.0.0.0/0 tunnel=yes
 add distance=1 dst-address=172.27.1.0/24 gateway=IPSEC_VPN
The IPSec tunnel looks to be up. I can see the remote peer in the status window. Have turned on IPSec debugging and can’t see a problem, but neither the router nor any clients can ping the server at 172.27.1.91
Here is the existing Cisco router config (Using slightly different credentials) that does work fine
crypto isakmp policy 10
 encr 3des
 hash md5
 authentication pre-share
 group 2
crypto isakmp key address xxx.12.184.137
crypto ipsec transform-set VPNExchangetrans esp-3des esp-md5-hmac
crypto map VPNExchangevpn 10 ipsec-isakmp
 set peer xxx.12.184.137
 set transform-set VPNExchangetrans
 match address 101
interface Loopback1
 ip address 172.29.73.187 255.255.255.255
interface [OUTSIDE INTERFACE]
 ip nat outside
 no ip route-cache
interface [LOCAL VLAN]
 ip nat inside
ip nat inside source route-map VPNExchangenat interface Loopback1
overload
ip nat inside source route-map internetnat interface [OUTSIDE INTERFACE] overload
access-list 101 remark packets to VPN
access-list 101 permit ip 192.168.0.0 0.0.0.255 172.27.1.0 0.0.0.255
access-list 101 permit ip host 172.29.xx.yy 172.27.1.0 0.0.0.255
access-list 101 permit ip 192.168.0.0 0.0.0.255 10.125.0.0 0.0.255.255
access-list 101 permit ip host 172.29.xx.yy 10.125.0.0 0.0.255.255
route-map VPNExchangenat permit 10
 match ip address 101
Any help???
There are a lot of additional options in the MikroTik that i’m not sure of, don’t know if they are required. For instance i’m pretty rusty and not sure if the Cisco config is running tunnel or transport mode (I would imagine tunnel). I’ve just tried to essentially mirror things the best I can on the Mikrotik side but alas, no ping responses
I’m not sure if i’m supposed to even use a bridge interface for the VPN or simply assign the IP to the existing outbound interface, i’m not sure if I need manual ip route commands or if the policy configured under IP->IPsec will take care of it. I don’t normally do IPSec whatsoever…
bump
1.) Your SA source and local IP address should be the public IP address of the MikroTik, basically the public IP address that is reachable from the Cisco. Otherwise it is trying to use a private IP address to communicate to a public one, that will not work unless NAT is involved, but then you need NAT Traversal. Just easier to use public IP addresses.
2.) You do not need to create a bridge. MikroTiks do not create a virtual interface for pure IPSec, it will handle the routing and everything you need. You do need an 172.29.43.0/24 address assigned to an interface, unless the IPSec is just terminating at the MikroTik and doesn’t go any further into the network.
IPSec peer defines who the MikroTik will talk to over IPSec. IPSec policy tells the MikroTik what traffic it will encrypt and who it will send that encrypted traffic to. IPSec policy tells the MikroTik how to encrypt the traffic.
