I have 1 bridge with 2 rb133 . I did not have problems until now . One RB133 become unusable after ver 3.10 upgrade . I’ve climbed the tower, get the board, put console cable . No boot sequence .
I installed mikrotik 2.9.51 with NetInstall . The key was ok, lvl 4 licence .
I maked a upgrade to 3.10, put the board on tha bag, climb the tower .
After connecting the cable i see on system - licence : lvl 0
What i must do ?
Please help me ! I tryed to put the key again, reboot, but the lvl was the same : 0 .
I can’t use wireless bridge and my clients call me .
Can you help ?
If i put 2.9.51, everything is ok, except the thing that signal for clients are not very good .
I want to run 3.10 firmaware . I have another RB133 and everything is ok on this board .
I run mikrotik 3.10 on my rb133 .
I have 1 day until my licence expires, but … the licence don’t expire . If i login again i have 23 min 56-59 minutes until expire, again and again .
How can i get away from this situation ?
I will soon change the board with a computer, but i want to clear the things .
Upgrade your Bootloader. Type “/system routerboard upgrade”
Get the key from Mikrotik.com “request key” and paste into the router. If after reboot it still complains, check the “/log print” to see if there were errors applying the key
I put all message type logging on, with output to memory, 1000 output lines .
I perform routerboard upgrade, update the key . But nothing . No error or output related to this upgrade or licence .
Uffff … should i climb the tower with a hammer ?
