need help with mikrotik tutorial.
hello all.
i have been setting up my internet cafe using mikrotik. i have two adsl connection each with 2MB bandwidth. i have successfully set it up using load balancing. simple queue for all my client PC. each PC limited to 256 Kbps download speed.
i got all the setup how to from the internet.
so if you ask me how i do it, all i can do is give you the links and its quite alot, because i just mix one setup and another.
you can say i am just figuring it all out by luck. and this is frustrating me. i need to know the theories behind all the technical stuff.
can anyone point me to any website that have a mikrotik theories tutorial.
i have been searching for it, and all i can find is technical tutorial such as how to do load balancing, and this and that. but i havent been able to find any mikrotik theories tutorial that explain how those technical stuff works.
thank you.
Greg Sowell videos are helpful.
http://wiki.mikrotik.com/wiki/MikroTik_RouterOS
don’t worry - the more frustrating it is the more rewarding it is when things start to click :slight_smile:
