need help with nat and p2p
hello.
i just upgraded from some old linksys to mikrotik hap and have trouble configuring my freenas server so that everything works. so far all is working good except torrent client cannot connect to trackers and links. where could be the problem?
Would probably need to start with posting an export of your configuration (without any passwords or anything else included), so we can see what is configured.
# jul/16/2015 21:33:45 by RouterOS 6.30
# software id = YJ1F-WC00
add admin-mac=E4:8D:8C:88:FE:DB auto-mac=no name=bridge-local
set [ find default-name=ether1 ] mac-address=00:13:05:89:FF:FF name=\
    ether1-gateway
set [ find default-name=ether2 ] name=ether2-master-local
set [ find default-name=ether3 ] master-port=ether2-master-local name=\
    ether3-slave-local
set [ find default-name=ether4 ] master-port=ether2-master-local name=\
    ether4-slave-local
/interface wireless
set [ find default-name=wlan1 ] antenna-gain=2 band=2ghz-onlyn channel-width=\
    20/40mhz-Ce country=latvia disabled=no distance=indoors frequency=auto \
    frequency-mode=superchannel l2mtu=1600 mode=ap-bridge rx-chains=0,1 ssid=\
    xxxxx tx-chains=0,1 wireless-protocol=802.11
/ip neighbor discovery
set ether1-gateway discover=no
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=\
    dynamic-keys wpa-pre-shared-key=xxxx wpa2-pre-shared-key=xxxx
add name=dhcp ranges=192.168.88.10-192.168.88.254
add address-pool=dhcp disabled=no interface=bridge-local name=default
add bridge=bridge-local interface=ether2-master-local
add bridge=bridge-local interface=wlan1
add address=192.168.88.1/24 comment="default configuration" interface=\
    ether2-master-local network=192.168.88.0
/ip dhcp-client
add comment="default configuration" dhcp-options=hostname,clientid disabled=\
    no interface=ether1-gateway
/ip dhcp-server lease
add address=192.168.88.251 client-id=1:0:50:8d:75:3a:9 mac-address=\
    00:50:8D:75:3A:09 server=default
add address=192.168.88.0/24 comment="default configuration" gateway=\
    192.168.88.1
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 name=router
add chain=input comment="default configuration" protocol=icmp
add chain=input comment="default configuration" connection-state=\
    established,related
add action=drop chain=input comment="default configuration" in-interface=\
    ether1-gateway
add chain=forward comment="default configuration" connection-state=\
    established,related
add action=drop chain=forward comment="default configuration" \
    connection-state=invalid
    connection-nat-state=!dstnat connection-state=new in-interface=\
    ether1-gateway
add chain=forward p2p=all-p2p
add action=masquerade chain=srcnat comment="default configuration" \
    out-interface=ether1-gateway
add action=dst-nat chain=dstnat dst-address=xxx dst-port=13134 \
    protocol=tcp to-addresses=192.168.88.251 to-ports=80
add action=dst-nat chain=dstnat dst-address=xxx dst-port=8888 \
    protocol=tcp to-addresses=192.168.88.12
add action=dst-nat chain=dstnat dst-address=xxx dst-port=51413 \
    protocol=tcp to-addresses=192.168.88.15
add action=dst-nat chain=dstnat dst-address=xxx dst-port=9091 \
add action=dst-nat chain=dstnat dst-address=xxx dst-port=4040 \
    protocol=tcp to-addresses=192.168.88.13 to-ports=4040
add action=dst-nat chain=dstnat dst-address=xxx dst-port=789 \
    protocol=tcp to-addresses=192.168.88.14 to-ports=80
    protocol=udp to-addresses=192.168.88.13
add action=masquerade chain=srcnat dst-address=192.168.88.0/24 src-address=\
    192.168.88.0/24
/ip upnp
set enabled=yes
/ip upnp interfaces
add interface=bridge-local type=internal
add interface=ether1-gateway type=external
/system clock
set time-zone-autodetect=no time-zone-name=Europe/Riga
/system routerboard settings
set cpu-frequency=650MHz protected-routerboot=disabled
/tool graphing interface
add
/tool graphing resource
add
/tool mac-server
add interface=ether2-master-local
add interface=ether3-slave-local
add interface=ether4-slave-local
add interface=wlan1
/tool mac-server mac-winbox
add interface=wlan1
/tool romon port
add
this is my config.
i guess everythings ok with router config, because i can upload and download in pc. so problem is in freenas config, still not sure what.
