Need help with NAT with multiple external IPs
HI all
I have a pretty basic setup, but I am having issues with getting the NAT to work properly on a MikroTik Cloud Router. Here is my setup
Usable External IP Range 1.101.81.96-102
Network 1.181.81.96/29
Subnet 255.255.255.248
Gateway 1.181.81.97
Internal LAN 192.168.88.0/24
DHCP Range 192.168.88.101-240
Primary DNS 8.8.8.8
Secondary DNS 4.4.4.4
The mikrotik router is at 192.168.88.1 on the LAN. I want to be able to connect to the router remotely from my IP address so I can manage it from home. I have added an IP address list entry called RichardWAN (see config below) so I can reference it in a rule to allow me to do this.
As of right now, the LAN is able to get out to internet. I have a NAS at 192.168.88.102 set with a static lease so it always gets the same address from DHCP. I am trying to NAT 1.101.81.100 to 192.168.88.102 and allow traffic on port 8080 from specific other hosts on the internet.
Here is my config, it might have some errors considering NAT does not appear to be working right now;
# mar/17/2020 02:48:53 by RouterOS 6.44.5
# software id = GVYY-AEWD
# model = CRS112-8P-4S
# serial number = 9B210BB7FF0F
add admin-mac=C4:AD:34:71:19:13 auto-mac=no comment=defconf name=bridge
set [ find default-name=ether1 ] name=ether1-WAN
set [ find default-name=ether4 ] comment="Connection to NAS\
    \n" name=ether4-NAS
set [ find default-name=ether6 ] comment="To Richards MBP" name=ether6-MBP
add name=WAN
add name=LAN
/ip hotspot profile
add name=dhcp ranges=192.168.88.100-192.168.88.254
add add-arp=yes address-pool=dhcp always-broadcast=yes bootp-support=dynamic \
    disabled=no interface=bridge name=dhcp1
add bridge=bridge comment=defconf interface=ether4-NAS
add bridge=bridge comment=defconf interface=ether6-MBP
add bridge=bridge comment=defconf interface=ether7
add bridge=bridge comment=defconf interface=ether8
add bridge=bridge comment=defconf interface=sfp9
add bridge=bridge comment=defconf interface=sfp10
add bridge=bridge comment=defconf interface=sfp11
add bridge=bridge comment=defconf interface=sfp12
add interface=ether1-WAN list=WAN
add interface=bridge list=LAN
add address=192.168.88.1/24 comment=defconf interface=ether2 network=\
    192.168.88.0
add address=1.181.81.99/29 interface=ether1-WAN network=1.181.81.96
add address=1.181.81.100 interface=ether1-WAN network=1.181.81.96
add address=1.181.81.101 interface=ether1-WAN network=1.181.81.96
add address=1.181.81.102 interface=ether1-WAN network=1.181.81.96
/ip dhcp-client
add dhcp-options=hostname,clientid interface=ether1-WAN
/ip dhcp-server lease
add address=192.168.88.102 client-id=1:24:5e:be:35:76:ad mac-address=\
    24:5E:BE:35:76:AD server=dhcp1
add address=192.168.88.0/24 dns-server=8.8.8.8 gateway=192.168.88.1 netmask=\
    24
set allow-remote-requests=no servers=8.8.8.8,4.4.4.4
/ip firewall address-list
add address=174.50.183.227 list=SteveExternal
add address=66.60.144.62 list=RichardWAN
add address=1.181.81.96/29 list=Public
add address=192.168.88.102 list=NAS
    established,related,untracked
    invalid
add action=accept chain=input comment="defconf: accept ICMP" disabled=yes \
    protocol=icmp
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    estmagablished,related,untracked
    connection-state=invalid
    "defconf:  drop all from WAN not DSTNATed" connection-nat-state=!dstnat \
add action=drop chain=forward disabled=yes dst-address-list=Public log=yes \
    protocol=icmp
Here is my attempt at dstnat’ing the 1.181.81.100 to 192.168.88.102 for port 8080.
add action=dst-nat chain=dstnat dst-address=1.181.81.100 log=yes protocol=\
    tcp src-address=73.235.116.199 src-port=8080 to-addresses=192.168.88.102 \
    to-ports=8080
add action=netmap chain=dstnat dst-address=1.181.81.100 log=yes protocol=\
    to-ports=8080
add distance=1 gateway=1.181.81.97
/system clock
set time-zone-name=America/Los_Angeles
Could someone please tell me how to get the NAT working properly?
First comment. If you are managing the router from an external site, use a VPN do to so, any other way is a security risk (well I suppose port knocking can be effective).
Okay PF needs
  1. A single firewall rule to allow destination packets to reach server
  2. A single source nat rule to keep track of outgoing packets assigned the router WANIP outbound (sourcenat if a fixed IP, masquerate action if a dynamic wanip)
  3. If you wish to access the server from the same subnet the server is on, simply use the LANIP of the server.
  4. If you wish to access the server by using the WANIP of the router (as if you were external) but from the same subnet as the server that is called HAIRPIN NAT and you will need
    an xtra source nat rule and will need to modify potentially the destination nat rule.
  5. For each server you will need a single destination nat rule
  6. If you can limite the external wanips requireing access the the server use source-address-list in the destination nat rule.
(1) Lets have a look at your destination nat rules… I have no experience with netmap so not looking at that one..
to-ports=8080
to-ports=8080
Corrected: Good on source address if it was more than one then a list. Change src-port to dst-port. Dont need to-port if same as dest port.
tcp src-address=73.235.116.199 dst-port=8080 to-addresses=192.168.88.102
(2) Lets look at source nat rules - no issues
(3) Looking at firewall rules… Seems your covered!
“defconf: drop all from WAN not DSTNATed” connection-nat-state=!dstnat
