Hi!
First of all, sorry about my English, I promess I will try to make this post easier to write and read ![]()
I was following these guides
http://wiki.mikrotik.com/wiki/Manual:PCC
http://wiki.mikrotik.com/wiki/Per-Traffic_Load_Balancing
and I have a little problem with one of my WAN connections, I currently have two WAN: one ordinary ADSL and one SDSL with static IP.
Recently, when I let the PCC work normally, internet becomes unusable from the LAN, so I created a mangle rule to mark all TCP 80 traffic and taking it to the ADSL gateway. The problem is, I have also a web server and with this mangle it gives me timed out connections when I try to get it using the static IP.
I don’t know if the SDSL issue comes from the router configuration (please see below) or the connection itself is lossing packets (pinging 8.8.8.8 gives me about 8% of packet loss).
I will post the configuration, so you can see in a more plain way what I mean and you can give me some advice something about that.
Addresses:
ip address print
# ADDRESS NETWORK INTERFACE
0 ;;; default configuration
10.81.1.1/24 10.81.1.0 ether2-master-local
1 ;;; SDSL WAN
190.228.137.179/29 190.228.137.176 ether1-gateway
2 [a pptp connection]
3 ;;; WAN 5 - ADSL
192.168.1.254/24 192.168.1.0 ether5 - WAN - ADSL 7M 313
[some L2TP connections]
NAT
ip firewall nat print
0 ;;; masquerade wan 1 (SDSL)
chain=srcnat action=masquerade to-addresses=0.0.0.0
out-interface=ether1-gateway
1 ;;; masquerade wan 5 (ADSL)
out-interface=ether5 - WAN - ADSL 7M 313
2 ;;; HTTP to ProLiant (10.81.1.15)
chain=dstnat action=dst-nat to-addresses=10.81.1.15 to-ports=80
protocol=tcp dst-address=190.228.137.179 dst-port=80
3 ;;; FTP to ProLiant (10.81.1.15)
chain=dstnat action=dst-nat to-addresses=10.81.1.10 to-ports=22
protocol=tcp dst-address=190.228.137.179 dst-port=22
4 ;;; uTorrent@Killerpc
chain=dstnat action=dst-nat to-addresses=10.81.1.129 to-ports=47228
protocol=tcp dst-address=190.228.137.179 dst-port=47228
5 ;;; RDP@Killerpc
chain=dstnat action=dst-nat to-addresses=10.81.1.129 to-ports=3389
protocol=tcp dst-address=190.228.137.179 dst-port=3389
6 ;;; uTorrent@Killerpc
protocol=udp dst-address=190.228.137.179 dst-port=47228
Address list:
ip firewall address print
Flags: X - disabled, D - dynamic
# LIST ADDRESS
0 local-networks 10.81.1.0/24
1 local-networks 10.81.3.0/24
2 local-networks 10.81.4.0/24
3 local-networks 10.81.5.0/24
4 local-networks 10.81.6.0/24
5 local-networks 10.81.7.0/24
6 local-networks 10.81.8.0/24
7 local-networks 192.168.1.0/24
8 local-networks 190.228.137.176/29
9 local-networks 192.168.88.0/24
10 webserver 10.81.1.15
from 0 to 6 are layer 2 tunnels
7 is the ADSL WAN
8 is the SDSL WAN
9 is another layer 2 tunnel
10 is the webserver
Mangle:
ip firewall mangle print
0 chain=prerouting action=accept dst-address=190.228.137.176/29
in-interface=ether2-master-local
1 chain=prerouting action=accept dst-address=192.168.1.0/24
2 ;;; Allow local networks (ping and sharing through L2TP)
chain=prerouting action=accept src-address-list=local-networks
dst-address-list=local-networks
3 ;;; Bypass webserver
chain=prerouting action=mark-routing new-routing-mark=Webserver
passthrough=no src-address-list=webserver
4 ;;; HTTPS and shoutcast Traffic Routing
new-routing-mark=HTTPS traffic routing passthrough=no protocol=tcp
dst-port=443,8004,8002
5 ;;; HTTP Traffic Routing
chain=prerouting action=mark-routing new-routing-mark=HTTP traffic routing
passthrough=no protocol=tcp routing-mark=!Webserver dst-port=80
6 ;;; Mark connection WAN 7M
chain=prerouting action=mark-connection new-connection-mark=wan_7M
passthrough=no connection-state=new
in-interface=ether5 - WAN - ADSL 7M 313 connection-mark=no-mark
7 ;;; Mark connection WAN SDSL
chain=prerouting action=mark-connection new-connection-mark=wan_SDSL
passthrough=no connection-state=new in-interface=ether1-gateway
8 ;;; Mark Connection WAN ADSL - 0
passthrough=no connection-state=new dst-address-type=!local
in-interface=ether2-master-local connection-mark=no-mark
per-connection-classifier=both-addresses-and-ports:2/0
9 ;;; Mark Connection WAN SDSL - 1
per-connection-classifier=both-addresses-and-ports:2/1
10 ;;; Mark Routing WAN ADSL
chain=prerouting action=mark-routing new-routing-mark=to_WAN 7M
passthrough=no in-interface=ether2-master-local connection-mark=wan_7M
11 ;;; Mark Routing WAN SDSL
chain=prerouting action=mark-routing new-routing-mark=to_WAN SDSL
passthrough=no in-interface=ether2-master-local connection-mark=wan_SDSL
12 ;;; Routing Mark WAN ADSL
chain=output action=mark-routing new-routing-mark=to_WAN 7M passthrough=no
13 ;;; Routing Mark WAN SDSL
chain=output action=mark-routing new-routing-mark=to_WAN SDSL
passthrough=no connection-mark=wan_SDSL
If I disable the 5th rule, the webserver works fine when requesting the static IP from outside, but Internet works slow as hell from the LAN. This rule with or without “routing-mark=!Webserver” the web server doesn’t works.
Routes:
ip route print detail
0 A S dst-address=0.0.0.0/0 gateway=190.228.137.177
gateway-status=190.228.137.177 reachable via ether1-gateway
check-gateway=ping distance=1 scope=30 target-scope=10
1 A S dst-address=0.0.0.0/0 gateway=192.168.1.1
gateway-status=192.168.1.1 reachable via ether5 - WAN - ADSL 7M 313
2 A S dst-address=0.0.0.0/0 gateway=192.168.1.1
3 A S dst-address=0.0.0.0/0 gateway=192.168.1.1
4 A S dst-address=0.0.0.0/0 gateway=190.228.137.177
5 A S dst-address=0.0.0.0/0 gateway=190.228.137.177
6 S dst-address=0.0.0.0/0 gateway=192.168.1.1
check-gateway=ping distance=2 scope=30 target-scope=10
7 ADC dst-address=10.81.1.0/24 pref-src=10.81.1.1 gateway=ether2-master-local
gateway-status=ether2-master-local reachable distance=0 scope=10
[...a bunch of l2tp connections]
22 ADC dst-address=190.228.137.176/29 pref-src=190.228.137.179
gateway=ether1-gateway gateway-status=ether1-gateway reachable
distance=0 scope=10
23 ADC dst-address=192.168.1.0/24 pref-src=192.168.1.254
gateway=ether5 - WAN - ADSL 7M 313
gateway-status=ether5 - WAN - ADSL 7M 313 reachable distance=0 scope=10
24 ADS [other l2tp]
Any help would be greatly appreciated ![]()
Edit 01:
I think I have this now working well… running some tests by now. Later I will update this post.
