Need Help with port forwarding
I am needing basic help with port forwarding please.
I have a Q-See unit QT428 and I am desperately find a way to be able to view my cameras via my computer. The router is Mikrotik 951 which was provided by my ISP but which I now own. I have upgraded the firmware on the Q-See and checked the UPnP box. However, when I try canyouseeme, it cannot read ports 85 or 6036.
I cannot get any help from Q-See as they tell me they are “not trained” on a Mikrotik router.
My ISP likewise cannot help.
I am really hoping someone here can walk me through this. I have password etc for the router but am afraid of messing it up as I know little about routers. The info from Mikrotik seems very complicated and I do not understand it.
A. Which IP has your Q-See unit ?
B. In Routerboard 951:
Go to “New Terminal” and type export.
Copy paste the results here.
The easiest way should be to enable UPnP on router (it’s disabled by default). Look at IP->UPnP, there’s Enabled checkbox. And you also need to tell router which interface is internal and external (there’s Interfaces button for that in same dialog).
Thank you for the response. The UPnP was already checked on the router. However, although I look at the interfaces button, I do not understand what to do with the info. It lists two items: bridge-local Internal and ether1-gateway external.
The IP for the QT is 192.168.001.239
router is 192.168.001.001
This is what I get at New Terminal (which make no sense to me!)
MMM MMM KKK TTTTTTTTTTT KKK
MMMM MMMM KKK TTTTTTTTTTT KKK
MMM MMMM MMM III KKK KKK RRRRRR OOOOOO TTT III KKK KKK
MMM MM MMM III KKKKK RRR RRR OOO OOO TTT III KKKKK
MMM MMM III KKK KKK RRRRRR OOO OOO TTT III KKK KKK
MMM MMM III KKK KKK RRR RRR OOOOOO TTT III KKK KKK
MikroTik RouterOS 6.30.4 (c) 1999-2015 http://www.mikrotik.com/
[?] Gives the list of available commands
command [?] Gives help on the command and list of arguments
[Tab] Completes the command/word. If the input is ambiguous,
a second [Tab] gives possible options
/ Move up to base level
.. Move up one level
/command Use command at the base level
Hi OceanWW,
Yes, it is normal what you see in “New Terminal”; what JB172 wanted to say is that in “New Terminal” window type export, hit enter and copy&paste results here.
kind regards,
Thanks for the help. I think I have it right this time.
[customer@Usr15020] > export
jan/01/2017 18:50:26 by RouterOS 6.30.4
software id = 9TMB-A6I8
add admin-mac=E4:8D:8C:45:49:2F auto-mac=no name=bridge-local
set [ find default-name=ether1 ] name=ether1-gateway
set [ find default-name=ether2 ] name=ether2-master-local
set [ find default-name=ether3 ] master-port=ether2-master-local name=\
ether3-slave-local
set [ find default-name=ether4 ] master-port=ether2-master-local name=\
ether4-slave-local
set [ find default-name=ether5 ] master-port=ether2-master-local name=\
ether5-slave-local
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n disabled=no distance=indoors \
l2mtu=1600 mode=ap-bridge mtu=1600 ssid=AlyricaWiFi wireless-protocol=\
802.11
/ip neighbor discovery
set ether1-gateway discover=no
set [ find default=yes ] authentication-types=wpa2-psk eap-methods=“” mode=\
dynamic-keys supplicant-identity=MikroTik wpa-pre-shared-key=rudolph10 \
wpa2-pre-shared-key=rudolph10
add name=dhcp ranges=192.168.1.10-192.168.1.254
add address-pool=dhcp disabled=no interface=bridge-local name=default
/queue simple
add name=queue1 queue=pcq-upload-default/pcq-download-default target=\
192.168.1.0/24
add bridge=bridge-local interface=ether2-master-local
add bridge=bridge-local interface=wlan1
add address=192.168.1.1/24 comment=Router interface=ether2-master-local \
network=192.168.1.0
/ip dhcp-client
add comment=“default configuration” dhcp-options=hostname,clientid disabled=\
no interface=ether1-gateway
add address=192.168.1.0/24 dns-server=8.8.8.8,199.58.96.29 gateway=\
192.168.1.1
set allow-remote-requests=yes
/ip dns static
add address=192.168.1.1 name=Router
add address=199.58.96.29 name=Alyrica
add address=8.8.8.8 name=Google
/ip firewall address-list
add address=69.1.125.0/24 list=Alyrica
add address=74.123.160.0/21 list=Alyrica
add address=104.152.252.0/22 list=Alyria
add address=192.234.118.0/23 list=Alyrica
add address=206.192.248.0/23 list=Alyrica
add address=199.58.96.0/21 list=Alyrica
add address=199.91.226.0/23 list=Alyrica
add address=199.91.230.0/23 list=Alyrica
add address=208.65.184.0/21 list=Alyrica
add address=206.192.248.0/24 list=Management
add address=199.58.96.0/24 list=Management
add address=199.91.230.0/23 list=Management
add address=208.65.184.0/21 list=NextGen
add address=74.123.160.0/21 list=NextGen
add chain=input comment=“Allow Alyrica Managment IPs” src-address-list=\
Management
add chain=input comment=“default configuration” protocol=icmp
add chain=input comment=“default configuration” connection-state=\
established,related
add action=drop chain=input comment=“default configuration” disabled=yes \
in-interface=ether1-gateway
add chain=forward comment=“default configuration” connection-state=\
established,related
add action=drop chain=forward comment=“default configuration” \
connection-state=invalid
connection-nat-state=!dstnat connection-state=new in-interface=\
ether1-gateway
established
add chain=forward comment=“default configuration” connection-state=related
add chain=output content=“530 Login incorrect” dst-limit=\
1/1m,9,dst-address/1m protocol=tcp
add action=add-dst-to-address-list address-list=ftp_blacklist \
address-list-timeout=3h chain=output content=“530 Login incorrect” \
protocol=tcp
add action=drop chain=forward comment=“drop ssh brute downstream” dst-port=22 \
protocol=tcp src-address-list=ssh_blacklist
add chain=input protocol=icmp
add chain=input connection-state=established
add chain=input connection-state=related
add action=drop chain=input in-interface=ether1-gateway
add action=masquerade chain=srcnat comment=“default configuration” \
out-interface=ether1-gateway
/ip ipsec policy
set 0 dst-address=0.0.0.0/0 src-address=0.0.0.0/0
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www address="192.168.1.0/24,69.1.125.0/24,199.91.230.0/24,206.192.248.0/25\
,199.58.96.0/25,208.65.184.0/21,74.123.160.0/21"
set ssh address="192.168.1.0/24,69.1.125.0/24,199.91.230.0/24,206.192.248.0/25\
set api disabled=yes
set winbox address="192.168.1.0/24,206.192.248.0/25,199.58.96.0/25,208.65.184.\
set api-ssl disabled=yes
/ip upnp
set enabled=yes
/ip upnp interfaces
add interface=ether1-gateway type=external
add interface=bridge-local type=internal
/system clock
set time-zone-name=America/Los_Angeles
/system identity
set name=Usr15020
/system leds
set 5 interface=wlan1
/system routerboard settings
set protected-routerboot=disabled
/tool mac-server
add interface=ether2-master-local
add interface=ether3-slave-local
add interface=ether4-slave-local
add interface=ether5-slave-local
add interface=wlan1
/tool mac-server mac-winbox
add interface=wlan1
/tool romon port
add
You want to access Q-See unit from internet or from inside your lan?
First of all, go to RB951 to IP->Addresses and change the interface of 192.168.1.1/24 from ether2-master-local to bridge-local
