Need Help With Routes
I currently have 2 mikrotik router boards with router os 4.5 installed on them. If you want here is a link to another forum where i have been troubleshooting the issue and it gives you a run down on what i am trying to do.
http://motorola.wirelessbroadbandsupport.com/support/community/viewtopic.php?f=1&t=6870&sid=56eecf5ac3f78f735a78595a48688fb2
In my last post you will see where i am having the problem
post from other forum
When I try to ping 192.168.1.1 or google.com’s ip from tower b I get a lot of packet loss from tower a I get no packet loss the reply I get when I ping is 192.168.100.1 92 byte redirect host (5:1) time<1 msFollowed by 192.168.1.1 ping timeout
The 192.168.1.1 is the router at our head end I just have it setup in the office right now for testing before we implement the devices.
Ok for tower a this is my setup
ether 1 ip = 192.168.1.21
ether 2 & 3 bonding 1 ip = 192.168.100.1
route list
AS dst add = 0.0.0.0/0 Gateway 192.168.1.1 reachable bridge 1
DAC dst add = 192.168.1.0/24 Gateway Bridge 1 Reachable
DAC 192.168.100.0/24 Gateway bridge 1
tower b
ether 1 ip = 192.168.2.21
ether 2 & 3 bonding 1 ip = 192.168.100.2
Route List
AS dst add = 0.0.0.0/0 Gateway 192.168.100.1 reachable bonding 1
AS dst add = 192.168.1.0/24 Gateway 192.168.100.1 reachable bonding 1
DAC dst add = 192.168.2.0/24 Gateway ether 1 reachable
DAC dst add = 192.168.100.0/24 Gateway bonding 1 reachable
Any input you guys have would be awesome thanks for all the great replies so far they have really helped out.
