I’ve been trying to get a T-Mobile (tmobile ? ) Rocket 2.0 device to work on my new hAP ac lite.
So far I can only make it work under Windows XP using the software that comes with the USB dongle.
I have tried Lubuntu and Fedora as well. If I use the setup GUI for it using as many settings from Windows XP as I could, I end up getting a solid blue light and an IP address, but that address seems to not be routed (I can’t ping the gateway). Seems like something is missing.
I can’t even make it get a solid blue light on the hAP ac lite.
I’m in the US (Arizona). Is there some setting I’m missing? I noticed there is a “Network ID” field that I don’t know what to put in there.
Thanks.
